I wanted to create an automation that runs Roomba once a week, but only when no-one is home. I am having a devil of a time getting reliable presence detection with IOS, so I decided to leave one manual step in the process. Now, when I leave, I say “Alexa tell Home Assistant we’re leaving” and, if it has been 7 days or more since the last time Roomba ran, then, Home Assistant will start Roomba. This intent also turns off all the lights. Special thanks to koalazak and the dorita980 project for getting the roomba stuff up and running.
Here’s the code:
First, I have a bash script that writes the current date to a text file, then it starts Roomba. Saving the date to a text file allows the date to persist through any kind of reboot.
/bin/date "+echo %b %d %Y" > /users/treno/.homeassistant/scripts/roombadate.sh
cd /Users/treno/projects/Roomba node roombastart.js
NOTE: this failed time after time until I finally realized that the Home Assistant process doesn’t have any PATH. So I have to hard-code the path to the date command as /bin/date.
Then I have a command line sensor to read that text file
- platform: command_line name : roombaRunDate command: /users/treno/ha/scripts/roombadate.sh scan_interval : 1
Now I have everything I need in Home Assistant to set up the SCRIPT for Alexa to run
goodbye: sequence: - service: homeassistant.turn_off entity_id: group.livingroom - service: homeassistant.turn_off entity_id : group.office - service: homeassistant.turn_off entity_id : switch.garage - service: homeassistant.turn_off entity_id : group.bedroom - condition: template value_template: '{{(((as_timestamp(now())-as_timestamp(strptime(states.sensor.roombarundate.state,"%b %d %Y")))/86400)| int)>6}}' - service: shell_command.rroomba
The template here does the date math to determine if it has been 7 days.
And Finally, the ALEXA intent code:
GoodbyeIntent: action: service: script.turn_on entity_id: script.goodbye speech: type: plaintext text: > "The house is in away mode." {% set elapsed = ((as_timestamp(now())-as_timestamp(strptime(states.sensor.roombarundate.state,"%b %d %Y")))/86400)| int%} {%if elapsed < 6 %} "Roomba will run in " {{7- elapsed}} "days" {% elif elapsed < 7 %} "Roomba will run tomorrow" {% else %} "Roomba will clean up while you are gone" {% endif %}
It was a fun couple of hours figuring out how to get all this stuff to work together.
I hope it helps someone out there with their own project.
