Alexa skill: can I access a "slot" in a template?
I want Alexa to tell me what the current temperature for a room is, e.g. “Alexa, ask homeassistant for the temperature in the livingroom”. I have created a custom skill with a “slot” (that’s what the variables are called, I believe) named “Room”.
How do I access this slot from within a template?
I tried:
speech:
  type: plaintext
  text: >
    {% if {{Room}} == 'livingroom' %}
which is apparently not the right syntax.
Leaving out the braces around Room completely, seems to be syntactically correct, but it doesn’t have the desired effect.
How do I do this correctly?
TIA,
Sebastian
Here is an example of what I think you are trying to do.
    MediaPlayerPlayPauseIntent:
        service: media_player.media_play_pause
        data_template:
          entity_id: media_player.{{ MediaPlayer | replace(" ", "_") }}
      speech:
        type: plaintext
        text: !include alexa_confirm.yaml
the MediaPlayer is in a slot/variable list in the Alexa interaction model. I have a list of the names of all of my media players in there.
I just read what you were asking again. You are trying to respond with a slot variable, not sure I know how to do that exactly how you are trying to do it, but… this is how my device tracker status works which is kinda similar.
    LocateIntent:
      speech:
        type: plaintext
        text: >
          {%- for state in states.device_tracker -%}
            {%- if state.name.lower() == User.lower() -%}
              {{ state.name }} is at {{ state.state }}
            {%- endif -%}
          {%- else -%}
            I am sorry, I do not know where {{ User }} is.
          {%- endfor -%}
Where User is the name spoken to Alexa.
Ah, thanks a lot!
So I can access it - in my case - just using Room as variable name.
I added a .lower() and now it seems to work! Great :slight_smile:
Sebastian
