I’m going to add the alexa integration via this this guideline. All worked very well but now I’m stuck at the point of linking the account from the developer console. I entered
Authorization URI: https://[MY WORKING DOMAIN]/auth/authorize
and
Access Token URI : https://[MY WORKING DOMAIN]/auth/token
but the alexa app does not discover any devices. When I call the entered domains manually, HA login screens appears with ‘Invalid redirect URI’
I already tried changing client ID from layla to pitangui but with no effect. Any suggestions?
No one any idea?
When I activate the dec skill in the alexa app, it just starts looking for new devices instead of entering the HA login screen…
Do you have this in your configuration.yaml
alexa:
smart_home:
endpoint: https://api.amazonalexa.com/v3/events
filter:
include_entities:
- cover.pc_curtains
- cover.bed_curtains
- media_player.monitor
I have set the endpoint https://api.eu.amazonalexa.com/v3/events as I’m located in Germany but no filters. When i read the instructions correctly, this is only optional. Or not?
You’ll have to adjust for locale, but I was under the impression it was not optional.
Ideally you want it, because Alexa will load every single entity you have in HA unless you control the filter
Just added 4 entities to try, but the alexa app still just searches devices and neither can’t find some nor the HA login screen appears…
alexa:
smart_home:
locale: de-DE
endpoint: https://api.eu.amazonalexa.com/v3/events
filter:
include_entities:
- climate.heizung_schlafzimmer
- sensor.schlafzimmer_temperatur
- climate.heizung_badezimmer
- sensor.badezimmer_temperatur
Keep that in your config and i’ll work backwards. My works flawlessly. May reach out via DM for security issues…
