Haven’t had any experience with zwave, however I have found that once it’s linked with HA Alexa “discovers” hundreds of things - I have several wireless tags and because they contain multiple sensors Alexa regards each one as about eight devices. It’s a good idea to go through the list in the Alexa app and disable the ones you don’t need - you may find that you have duplicates.
There are a lot of devices, that’s true. But this is not the problem that I am talking about. The problem is that Alexa doesn’t interact properly with the devices, even if they are correctly discovered.
I think that the problem is related with a time out in Alexa’s response, or in the device state change… But I don’t know how to solve it.
Newbie here, installed HA last week and having the same issues. Works fine but always get the feedback from Alexa that device unresponsive.
It’s as if Alexa cannot read the status either as although light may turn on Alexa still says off.
Anyone else have issues? I also have one plug that although in HA will not be discovered by Alexa despite being one of several all via SmartLife. The rest are working fine.
I have the same issue… the device is discovered but it is not working properly. I can’t turn the lights on or off. When I select the device, instead of a power button, Alexa displays the device properties, as in this example:
I’m using the raspberry Pi with nginx and accessing the port 8443, since the 443 is blocked by my operator. Other than that, everything else is strictly the same as the Alexa integration tutorial.
Anyone knows what is going on or how to debug and discover the error?
In my case, I changed the locale and removed the client id and secret. I don’t know why, the variables endpoint and/or locale were causing the discovery devices process to block the devices capabilities:
I have the same problem. Current version of HA with Alexa integration. When I ask her to turn off/on lights, she does it (lights turn off / on as expected). But then Alex says “Sorry, something went wrong”. This used to work without a problem.
since year ago, i used alexa skill on my devices without any problem, a few months ago, i got the “device is not responding”. I check the Skill it’s linked proprely, the devices are showen in alexa app. DNS and NGIX was updated and restart over, but the same issue, alexa still not responding with voice control.
Does anyone find a idea to fix this problem?
