Hi all, updated to the latest version (v.2.1.1) of ‘Alexa talking Clock’, upon starting appdaemon 4.0 an error is displayed at initialization. Anyone encountered this issue?
Add-on: AppDaemon 4
Python Apps and Dashboard using AppDaemon 4.x for Home Assistant
Add-on version: 0.2.5
You are running the latest version of this add-on.
System: HassOS 3.13 (armv7 / raspberrypi3)
Home Assistant Core: 0.109.6
Home Assistant Supervisor: 222
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] appdaemon.sh: executing...
[cont-init.d] appdaemon.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[13:13:37] INFO: Starting AppDaemon...
2020-05-08 13:13:42.184650 INFO AppDaemon: AppDaemon Version 4.0.3 starting
2020-05-08 13:13:42.185548 INFO AppDaemon: Python version is 3.8.2
2020-05-08 13:13:42.186491 INFO AppDaemon: Configuration read from: /config/appdaemon/appdaemon.yaml
2020-05-08 13:13:42.188180 INFO AppDaemon: Added log: AppDaemon
2020-05-08 13:13:42.189819 INFO AppDaemon: Added log: Error
2020-05-08 13:13:42.191337 INFO AppDaemon: Added log: Access
2020-05-08 13:13:42.192603 INFO AppDaemon: Added log: Diag
2020-05-08 13:13:42.277752 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2020-05-08 13:13:42.382011 INFO HASS: HASS Plugin Initializing
2020-05-08 13:13:42.383427 INFO HASS: HASS Plugin initialization complete
2020-05-08 13:13:42.385951 INFO AppDaemon: Initializing HTTP
2020-05-08 13:13:42.389018 INFO AppDaemon: Using 'ws' for event stream
2020-05-08 13:13:42.454992 INFO AppDaemon: Starting API
2020-05-08 13:13:42.487628 INFO AppDaemon: Starting Admin Interface
2020-05-08 13:13:42.489920 INFO AppDaemon: Starting Dashboards
2020-05-08 13:13:42.535216 INFO HASS: Connected to Home Assistant 0.109.6
2020-05-08 13:13:42.597332 INFO AppDaemon: App 'alexa_talking_clock' added
2020-05-08 13:13:42.601814 INFO AppDaemon: Found 1 total apps
2020-05-08 13:13:42.604393 INFO AppDaemon: Starting Apps with 1 workers and 1 pins
2020-05-08 13:13:42.609061 INFO AppDaemon: Running on port 5050
2020-05-08 13:13:42.719726 INFO HASS: Evaluating startup conditions
2020-05-08 13:13:42.835286 INFO AppDaemon: Got initial state from namespace default
2020-05-08 13:13:44.629337 INFO AppDaemon: Scheduler running in realtime
2020-05-08 13:13:44.645844 INFO AppDaemon: Adding /config/appdaemon/apps to module import path
2020-05-08 13:13:44.649524 INFO AppDaemon: Adding /config/appdaemon/apps/ad-alexatalkingclock to module import path
2020-05-08 13:13:44.651655 INFO AppDaemon: Adding /config/appdaemon/apps/ad-alexatalkingclock/apps to module import path
2020-05-08 13:13:44.653605 INFO AppDaemon: Adding /config/appdaemon/apps/ad-alexatalkingclock/apps/alexa_talking_clock to module import path
2020-05-08 13:13:44.655687 INFO AppDaemon: Adding /config/appdaemon/apps/alexa_talking_clock to module import path
2020-05-08 13:13:44.657621 INFO AppDaemon: Adding /config/appdaemon/apps/alexa_talking_clock/apps to module import path
2020-05-08 13:13:44.659625 INFO AppDaemon: Adding /config/appdaemon/apps/alexa_talking_clock/apps/alexa_talking_clock to module import path
2020-05-08 13:13:44.671542 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/ad-alexatalkingclock/apps/alexa_talking_clock/alexa_talking_clock.py
2020-05-08 13:13:44.700221 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/alexa_talking_clock/apps/alexa_talking_clock/alexa_talking_clock.py
2020-05-08 13:13:44.705337 INFO AppDaemon: Initializing app alexa_talking_clock using class AlexaTalkingClock from module alexa_talking_clock
**2020-05-08 13:13:44.713966 WARNING alexa_talking_clock: ------------------------------------------------------------**
**2020-05-08 13:13:44.715669 WARNING alexa_talking_clock: Unexpected error running initialize() for alexa_talking_clock**
**2020-05-08 13:13:44.717247 WARNING alexa_talking_clock: ------------------------------------------------------------**
**2020-05-08 13:13:44.727282 WARNING alexa_talking_clock: Traceback (most recent call last):**
** File "/usr/lib/python3.8/site-packages/appdaemon/app_management.py", line 145, in initialize_app**
** await utils.run_in_executor(self, init)**
** File "/usr/lib/python3.8/site-packages/appdaemon/utils.py", line 276, in run_in_executor**
** response = future.result()**
** File "/usr/lib/python3.8/concurrent/futures/thread.py", line 57, in run**
** result = self.fn(*self.args, **self.kwargs)**
** File "/config/appdaemon/apps/alexa_talking_clock/apps/alexa_talking_clock/alexa_talking_clock.py", line 25, in initialize**
** self.alexa = self.args["alexa"]**
**KeyError: 'alexa'**
2020-05-08 13:13:44.729161 WARNING alexa_talking_clock: ------------------------------------------------------------
2020-05-08 13:13:44.734885 INFO AppDaemon: App initialization complete
2020-05-08 13:13:53.804900 INFO AppDaemon: New client Admin Browser connected
2020-05-08 13:14:28.364191 INFO AppDaemon: Unexpected client disconnection from Admin Browser
2020-05-08 13:14:48.154933 INFO AppDaemon: New client Admin Browser connected
