I have three Alexa Echo Dots and tried to use TTS, but it’s only working for one of the echos. I tried all kinds of yaml-Code - it’s always working with the one echo, the other two won’t work.
Did someone has a similiar issue?
My code is working, since with one Echo everything is working super smoothly. It’s just that the other two don’t react on TTS…
Someone an idea?
service: notify.alexa_media_echo_dot_arbeitszimmer
message: Test
type: announce
method: all
Thanks for the input - that was not the case. But I found the solution:
I deleted the two not working echo dots from the alexa app, unplugged them, did a reset of the echos dots and added them again to the alexa app - and then it finally worked!
Same problem over here : some echos wouldn’t respond to tts/announce commands tested through the Developer Tools/Services tab.
I had to simply unplug/replug the Echos to make them work
For info, here are 3 ways to make them speak :
message: 'hello humans'
target: media_player.kitchen
type: announce #announcement preceded by a chime
