Thank you all! I was asking because until 1/2 weeks ago I was able to open the gate, now I need to turn on the gate. Thought that some Alexa’s update broke my configuration.
@Markus99, are you able to open and not turn on your gate with Alexa?
I ended up using routines for some of my stuff. There is a post about making a “dummy” or “virtual” light quite awhile back and that has worked great for me. You can make the routine use any wording you want, only downside is with the recent emulated hue issues if the bulb gets removed from Alexa you have to go back through and setup the brightness for every routine again.
Personally I use Google assistant / Google home and not Alexa. To be honest I haven’t set up the Google Assistant integration with home assistant but rather use ( and please don’t judge me) IFTTT. I’ve simply built a handful of IFTTT recipes (GA->HA webhook) which launch various scripts to handle turning on and off for opening and closing devices.
It’s certainly not my preferred long-term solution but for now it works and I just don’t have the time available though spare to dig in further.
