I ended up using routines for some of my stuff. There is a post about making a “dummy” or “virtual” light quite awhile back and that has worked great for me. You can make the routine use any wording you want, only downside is with the recent emulated hue issues if the bulb gets removed from Alexa you have to go back through and setup the brightness for every routine again.
