camrun91
(Camrun91)
August 5, 2016, 1:34pm
1
I have set up the Alexa/Echo component. I have also set up the skill on Amazons developer service. I am getting a message from the Echo that it is unable to connect. The exact error from the echo is
Request Identifier amzn1.echo-api.request.**************
A connection could not be established to Resource
[https://myexternalhost */api/alexa?api_password=mypassword ], Type [HTTP]
Did you configure HA to use SSL and are your certificates valid?
camrun91
(Camrun91)
August 5, 2016, 1:47pm
3
They are valid but self signed my next step was to try doing it with a signed cert
I did have some trouble with self signed certs myself and just switched over to letsencrypt free SSL-cert. Worked perfectly for me.
I am using Letsencrypt SSL certificate on Ubuntu and works really good.
rpitera
(Robert Pitera)
August 5, 2016, 3:15pm
6
I don’t think AWS allows for self-signed certs, even in dev mode. I know it definitely wouldn’t allow it for a published skill.
PhyberApex
(Phyber Apex)
August 5, 2016, 10:07pm
7
You can use self signed but you have to provide the private key iirc. At least for not published skills
rpitera
(Robert Pitera)
August 6, 2016, 12:30pm
8
Didn’t know that - good piece of info Phyber!
camrun91
(Camrun91)
August 10, 2016, 12:57pm
9
I have it working now. Looks like I may have had the port-forwarding wrong on my firewall. Changed that as well as a signed cert and everything is working fine now.
