Hi All,
Google assistant works then I try to connect home assistant to Alexa . At this stage unsuccessfully with “unable to link home assistant”. When testing the function with the long term token, no issue I get the list of devices.
Some data on the current setup:
- home assistant supervised in parallel to (not exhaustive) nextcloud, octoprint. All servers accessible through internet without issue
home assistant config for http:
- http:
use_x_forwarded_for: true
trusted_proxies:- 192.168.1.0/24
- 127.0.0.1
- haproxy; letsencrypt key type ECDSA:
- access to home assistant from internet through port 8223 (not 443)
The only log I get from home assistant is :
Logger: homeassistant.components.http.ban
Source: components/http/ban.py:129
Integration: HTTP (documentation, issues)
First occurred: 7 janvier 2024 à 08:31:00 (1 occurrences)
Last logged: 7 janvier 2024 à 08:31:00Login attempt or request with invalid authentication from 192.168.1.254 (192.168.1.254). Requested URL: ‘/auth/login_flow/6e2aca0c0efdcf81c530dab6ffaa404d’. (Mozilla/5.0 (Linux; Android 10; K) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Mobile Safari/537.36)
I don’t know how to get logs with more details, any idea how to fix this ?
