Alexa via NabuCasa is no longer triggering Scene
I have facing a problem which is driving me crazy. I can see that all the scenes are sync in Alexa and available, but whenever I ask Alexa to activate a scene I just an “ok” without any result. Even in the logbook there is no trace of the activity.
I already tried to remove/add the skill, remove all the scenes, resync all the entities, create new scenes. But nothing. Seems that now scenes via Alexa are broken for me.
Do you know if there is maybe a new issue? I am running HA2022.9.
Seems like that now to activate a scene I have to say “Alexa, activate scene xyz”. Not sure if something has been change on Alexa.
Solved: to trigger a scene you need to create a routine in Alexa. If you resync them the association between scene and routine has to be remade.
I am bumping this because in the last 24 hours or so and for some reason, the actions to activate HA scenes that are associated with all of my Alexa routines all disappeared from Alexa. I keep my HA instance regularly updated so I don’t know if updating to HA OS 10 or other update caused it. All I know is that voice activating a scene via Alexa just stopped working. To troubleshoot, I confirmed that activating the scene through Lovelace worked. I also confirmed that voice activating individual devices still work. I then went to the Routines section of the Alexa app and when I checked, in every routine to activate a scene, the action to so activate the scene was gone. I restored each scene action and everything works again.
I also updated the OS to version 10, but I haven’t experienced this issue. Maybe did your scene changed their ID?
Anyway this sounds to me more an issue related to Alexa, rather than to HA.
