Alexbelgium repo : 90+ addons
Strange, can you please post your full log? Have you finalised the installation, intialized the database and can access normally the addon? In the log above the initialization was not finalised and so nextcloud was reported as not installed
sorry skip the last line… its ok now.
I deeply apologize. I enabled autobuild as recommended by the HA guidelines, and it brought 2 big issues :
  • Multi-arch base images are not supported (it needs a pull --platform tag that is not implemented yet, and the system is very complex to fork and customize)
  • Upgrade from a locally built addon to an autobuilt addon is not supported : the addon still tries to locally build and then provides a failure message as it doesn’t find a local image…
I have decided to revert the changes. This means that everyone that has installed the new versions pushed since 2 days will have to restore a backup, or uninstall the app and reinstall it…
I’ve written a small how-to here : READ FIRST : Images not found · Issue #177 · alexbelgium/hassio-addons · GitHub
Thanks for your understanding.
Clear to me. Sorry is not needed. You do your best to make it always even better. Sometimes a brick will happen. But hey, always backup before upgrade… Thanks for all the support and all the great Addons!
Thanks for all the add-ons and time to support it… really appreciate it… I believe each of us here appreciate your effort and will live with little hiccup.
the update for Firefly importer give a error:
manifest for fireflyiii/data-importer:version-0.7.0 not found: manifest unknown: manifest unknown
Thanks, the firefly team pushed the version on github but their own docker builder automation doesn’t seem to have run. I’ll push a new version and link their update to the dockerhub repo instead of the github repo to avoid recurrence.
Edit : addon version 0-6-5 is up
New addons :
Installed Spotweb. Add my news account into it. But no information. Also see lots of errors:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] nginx: applying...
[fix-attrs.d] nginx: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-aaa_dockerfile_backup.sh: executing...
[cont-init.d] 00-aaa_dockerfile_backup.sh: exited 0.
[cont-init.d] 00-banner.sh: executing...
hello
 Add-on: Spotweb by @woutercoppens
 Spotweb is a decentralized usenet community based on the Spotnet protocol
 Add-on version: 1.5.1
 You are running the latest version of this add-on.
 System: Home Assistant OS 7.1  (aarch64 / raspberrypi4-64)
 Home Assistant Core: 2021.12.10
 Home Assistant Supervisor: 2021.12.2
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums
 https://github.com/alexbelgium/hassio-addons
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 90-spotweb: executing...
[22:36:32] WARNING: Spotweb is using the Maria DB addon
[22:36:32] WARNING: Please ensure this is included in your backups
[22:36:32] WARNING: Uninstalling the MariaDB addon will remove any data
core-mariadb (172.30.33.0:3306) open
[22:36:32] INFO: Existing database, checking health with upgrade-db....
[cont-init.d] 90-spotweb: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[22:36:35] INFO: Starting PHP-FPM...
[22:36:35] INFO: Starting NGinx...
2022/01/22 22:36:58 [error] 517#517: *3 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET / HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "ha.XXXXX.nl"
2022/01/22 22:37:43 [error] 517#517: *7 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET / HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123"
2022/01/22 22:37:43 [error] 517#517: *10 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET /?page=statics&type=css&mod=1642875491 HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123", referrer: "http://192.168.100.24:8123/api/hassio_ingress/j5qgiOgrkJBGoZ2DVqUaXLX-nz7SSFpG-CB4qrJ80SQ/"
2022/01/22 22:37:43 [error] 517#517: *14 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET /?page=statics&type=js&lang=nl_NL&mod=1642875492 HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123", referrer: "http://192.168.100.24:8123/api/hassio_ingress/j5qgiOgrkJBGoZ2DVqUaXLX-nz7SSFpG-CB4qrJ80SQ/"
2022/01/22 22:37:47 [error] 517#517: *28 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET /?page=editsettings HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123", referrer: "http://192.168.100.24:8123/api/hassio_ingress/j5qgiOgrkJBGoZ2DVqUaXLX-nz7SSFpG-CB4qrJ80SQ/"
2022/01/22 22:38:01 [error] 517#517: *49 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 127.0.0.1, server: _, request: "POST /?page=editsettings HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123", referrer: "http://192.168.100.24:8123/api/hassio_ingress/j5qgiOgrkJBGoZ2DVqUaXLX-nz7SSFpG-CB4qrJ80SQ/?page=editsettings"
2022/01/22 22:38:01 [error] 517#517: *52 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET / HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123", referrer: "http://192.168.100.24:8123/api/hassio_ingress/j5qgiOgrkJBGoZ2DVqUaXLX-nz7SSFpG-CB4qrJ80SQ/?page=editsettings"
2022/01/22 22:38:05 [error] 517#517: *56 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET /?search%5Btree%5D=&search%5Bunfiltered%5D=true HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123", referrer: "http://192.168.100.24:8123/api/hassio_ingress/j5qgiOgrkJBGoZ2DVqUaXLX-nz7SSFpG-CB4qrJ80SQ/"
2022/01/22 22:38:11 [error] 517#517: *60 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET /?page=login&data%5Bhtmlheaderssent%5D=true HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123", referrer: "http://192.168.100.24:8123/api/hassio_ingress/j5qgiOgrkJBGoZ2DVqUaXLX-nz7SSFpG-CB4qrJ80SQ/?search[tree]=&search[unfiltered]=true"
2022/01/22 22:38:15 [error] 517#517: *66 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 127.0.0.1, server: _, request: "POST /?page=login HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123", referrer: "http://192.168.100.24:8123/api/hassio_ingress/j5qgiOgrkJBGoZ2DVqUaXLX-nz7SSFpG-CB4qrJ80SQ/?search[tree]=&search[unfiltered]=true"
2022/01/22 22:38:20 [error] 517#517: *72 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET /?page=createuser HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123", referrer: "http://192.168.100.24:8123/api/hassio_ingress/j5qgiOgrkJBGoZ2DVqUaXLX-nz7SSFpG-CB4qrJ80SQ/?search[tree]=&search[unfiltered]=true"
2022/01/22 22:38:26 [error] 517#517: *76 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET /?page=edituserprefs&userid=1 HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123", referrer: "http://192.168.100.24:8123/api/hassio_ingress/j5qgiOgrkJBGoZ2DVqUaXLX-nz7SSFpG-CB4qrJ80SQ/?search[tree]=&search[unfiltered]=true"
2022/01/22 22:39:11 [error] 517#517: *80 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 127.0.0.1, server: _, request: "POST /?page=edituserprefs HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123", referrer: "http://192.168.100.24:8123/api/hassio_ingress/j5qgiOgrkJBGoZ2DVqUaXLX-nz7SSFpG-CB4qrJ80SQ/?page=edituserprefs&userid=1"
2022/01/22 22:44:46 [error] 517#517: *376 FastCGI sent in stderr: "PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pData.class.php on line 97PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pPie.class.php on line 1661PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /app/vendor/pchart/class/pPie.class.php on line 1661PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pData.class.php on line 170PHP message: PHP Fatal error:  Uncaught TypeError: array_sum(): Argument #1 ($array) must be of type array, null given in /app/vendor/pchart/class/pData.class.php:170
Stack trace:
#0 /app/vendor/pchart/class/pData.class.php(170): array_sum()
#1 /app/vendor/pchart/class/pPie.class.php(383): pData->getSum()
#2 /app/lib/services/Image/Services_Image_Chart.php(77): pPie->draw3DPie()
#3 /app/lib/services/Providers/Services_Providers_Statistics.php(128): Services_Image_Chart->renderChart()
#4 /app/lib/services/Providers/Services_Providers_Statistics.php(67): Services_Providers_Statistics->createStatsPerCategory()
#5 /app/lib/page/SpotPage_getimage.php(42): Services_Providers_Statistics->renderStatImage()
#6 /app/index.php(180): SpotPage_getimage->render()
#7 {main}
  thrown in /app/vendor/pchart/class/pData.class.php on line 170" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET /?page=getimage&image%5Btype%5D=statistics&image%5Bgraph%5D=spotspercategory&image%5Blimit%5D= HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123", referrer: "http://192.168.100.24:8123/api/hassio_ingress/j5qgiOgrkJBGoZ2DVqUaXLX-nz7SSFpG-CB4qrJ80SQ/?page=statistics"
2022/01/22 22:44:46 [error] 517#517: *382 FastCGI sent in stderr: "PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pData.class.php on line 97PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pDraw.class.php on line 5296PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pDraw.class.php on line 5346PHP message: PHP Warning:  Trying to access array offset on value of type null in /app/vendor/pchart/class/pDraw.class.php on line 5346PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pDraw.class.php on line 5394PHP message: PHP Warning:  Trying to access array offset on value of type null in /app/vendor/pchart/class/pDraw.class.php on line 5394PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pDraw.class.php on line 5396PHP message: PHP Warning:  Trying to access array offset on value of type null in /app/vendor/pchart/class/pDraw.class.php on line 5396" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET /?page=getimage&image%5Btype%5D=statistics&image%5Bgraph%5D=spotsperweekday&image%5Blimit%5D= HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123", referrer: "http://192.168.100.24:8123/api/hassio_ingress/j5qgiOgrkJBGoZ2DVqUaXLX-nz7SSFpG-CB4qrJ80SQ/?page=statistics"
2022/01/22 22:44:46 [error] 517#517: *387 FastCGI sent in stderr: "PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pData.class.php on line 97PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pDraw.class.php on line 5296PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pDraw.class.php on line 5346PHP message: PHP Warning:  Trying to access array offset on value of type null in /app/vendor/pchart/class/pDraw.class.php on line 5346PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pDraw.class.php on line 5394PHP message: PHP Warning:  Trying to access array offset on value of type null in /app/vendor/pchart/class/pDraw.class.php on line 5394PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pDraw.class.php on line 5396PHP message: PHP Warning:  Trying to access array offset on value of type null in /app/vendor/pchart/class/pDraw.class.php on line 5396" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET /?page=getimage&image%5Btype%5D=statistics&image%5Bgraph%5D=spotspermonth&image%5Blimit%5D= HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123", referrer: "http://192.168.100.24:8123/api/hassio_ingress/j5qgiOgrkJBGoZ2DVqUaXLX-nz7SSFpG-CB4qrJ80SQ/?page=statistics"
2022/01/22 22:44:46 [error] 517#517: *385 FastCGI sent in stderr: "PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pData.class.php on line 97PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pDraw.class.php on line 5296PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pDraw.class.php on line 5346PHP message: PHP Warning:  Trying to access array offset on value of type null in /app/vendor/pchart/class/pDraw.class.php on line 5346PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pDraw.class.php on line 5394PHP message: PHP Warning:  Trying to access array offset on value of type null in /app/vendor/pchart/class/pDraw.class.php on line 5394PHP message: PHP Warning:  Undefined array key "Data" in /app/vendor/pchart/class/pDraw.class.php on line 5396PHP message: PHP Warning:  Trying to access array offset on value of type null in /app/vendor/pchart/class/pDraw.class.php on line 5396" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET /?page=getimage&image%5Btype%5D=statistics&image%5Bgraph%5D=spotsperhour&image%5Blimit%5D= HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:8123", referrer: "http://192.168.100.24:8123/api/hassio_ingress/j5qgiOgrkJBGoZ2DVqUaXLX-nz7SSFpG-CB4qrJ80SQ/?page=statistics"
Hi @woutercoppens, any ideas?
Hi, I’m not sure it can access directly an addon. You should try with a direct ip. It seems to try to resolve with 127.0.0.1, which can’t work as it is not in the same container
I thought when I add my news server the information will be fetched and stored in dB. I’m now access from a ip with port. But see also errors and nothing loaded.
@woutercoppens can you assist?
2022/01/23 11:59:01 [error] 517#517: *104 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 192.168.100.29, server: _, request: "GET / HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:1000", referrer: "http://192.168.100.24:1000/"
2022/01/23 11:59:01 [error] 517#517: *108 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 192.168.100.29, server: _, request: "GET /?page=statics&type=css&mod=1642875491 HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:1000", referrer: "http://192.168.100.24:1000/"
2022/01/23 11:59:01 [error] 517#517: *104 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 192.168.100.29, server: _, request: "GET /?page=statics&type=js&lang=en_US&mod=1642875492 HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:1000", referrer: "http://192.168.100.24:1000/"
2022/01/23 11:59:10 [error] 517#517: *113 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 192.168.100.29, server: _, request: "GET /?page=edituserprefs&userid=2 HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:1000", referrer: "http://192.168.100.24:1000/"
2022/01/23 11:59:13 [error] 517#517: *116 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 192.168.100.29, server: _, request: "GET /?page=render&tplname=editspotterblacklist HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:1000", referrer: "http://192.168.100.24:1000/?page=edituserprefs&userid=2"
2022/01/23 12:00:18 [error] 517#517: *118 FastCGI sent in stderr: "PHP message: ERROR: Could not decode json-data for NZBGet method 'status', http returncode: 700 / Could not resolve host: addon_62c7908d_nzbget_docker" while reading response header from upstream, client: 192.168.100.29, server: _, request: "POST /?page=edituserprefs HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:1000", referrer: "http://192.168.100.24:1000/?page=edituserprefs&userid=2"
2022/01/23 12:00:38 [error] 517#517: *125 FastCGI sent in stderr: "PHP message: The configured NZB handler has no api support" while reading response header from upstream, client: 192.168.100.29, server: _, request: "GET /?page=nzbhandlerapi&nzbhandlerapikey=63c50d316b126779a2d2753aefd80233d5b0f956&action=getstatus HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.24:1000", referrer: "http://192.168.100.24:1000/"
If I read this article: https://4usenet.nl/spotweb-downloaden-installeren/
They say you get a screen to enter a pay server and if you want make your server public, private etc.
When I installed the add-on I directly comes into the interface of spotweb
@poudenes: check the correct hostname of your nzbget addon:
on my test system it’s local-nzbget.
I’ll have to check where addon_62c7908d_nzbget_docker come from.
I assume that your Home Assistant is running privately and that you don’t open it to the whole world?
The idea of this plugin is that it’s only accessible from your local network. That’s why I have put it in public mode, so you don’t have to bother with api keys.
When using the mariadb-addon, it will automatically create the database. All you have to do, is configure your usenet server and download client.
I have add my usenet client. But don’t see any information.
Must the nzbclient running before I see the info?
Spots are retrieved via a cronjob. It runs every hour. You’ll have to wait until the next hour until you’ll see some results.
The first time it’s run and it has to retrieve all the spots, it can take quite some time depending on the specs of your system. On my system it ran for more than 24 hours for the first retrieval.
Thanks. Let me see over 24hours :slight_smile: (In HA on RPi4)
We’ll update the documentation so it’s clear for everybody :wink:
I have installed spotweb lite on my OSX machine. Add newsreader and within 3 minutes everything was done.
On the add-on there is still nothing…
Schermafbeelding 2022-01-24 om 16.36.20
I think there is something wrong but don’t know what…
Schermafbeelding 2022-01-24 om 16.37.31
Installed Photoprism. When you restart the container, the data and settings are not saved, do you also? How to set up connection to MariaDB in HA?
