Alfen Eve Pro EV chargepoint interface via TCP modbus
Correct! That worked for me
Anyone else having problems with modbus and HA 10.5? The moment I installed 10.5 all modbus config and automations are giving errors all over the place.
Had to revert everything to the previous 9.x version.
Hi Dieter,
I have the same problems here. After I upgraded to 23.10.0 HA started in safe mode and the log showed all kinds of errors about modbus.
same here, modbus errors after updating to the latest version
from the homeassistant github:
remove the count: 4 line from the config
Hi @hollie
after your hint, I opened a ticket to Alfen TechSupport and I got this answer:
Currently, there is no ā€œright settingā€ to use. MaxStationCurrent should be the value of the fuse that is protecting the charging station. Setting this value too high will allow the station to blow the fuse. A better setting to use would be Connector #1 maximum current (ā€œmain_normal_max_current_socket_1ā€). That will allow the station fuse to be protected by the charging station as set in MaxStationCurrent. Because Alfen does not have an official Home Automation interface, there is no other parameter to use for momentary changes of offered current
the HACS expose the ā€˜main_normal_max_current_socket_1ā€™ parameter as ā€˜power_connector_max_current_socket_1ā€™ so Iā€™m now able to easily control the current via HA:
Dan
Hi @hollie ,
Thank you so much for doing all the work and sharing it.
Couldnā€™t have figured it out without this.
For people wanting to do the conversion from the desired Amperage in float32 to the two int16 values: Home Assistant Jinja templates (Python) also support the pack and unpack functions. So this is the script I used:
alias: set_modbus_maxcurrent
variables:
  value_a: 0
sequence:
  - service: modbus.write_register
      address: 1210
      unit: 1
      hub: chargepoint
      value:
        - "{{ (value_a | pack(\">f\") | unpack(\">I\")) // 2**16 }}"
        - "{{ (value_a | pack(\">f\") | unpack(\">I\")) % 2**16 }}"
mode: single
I created an automation that calls this script, so everything is handled in Home Assistant. Some helper input booleans and numbers allow controlling the charging process from a dashboard.
Cheers,
Tars
Hey @tars,
youā€™re welcome!
Very useful addition to this topic. I have just migrated the Perl script I wrote some time ago to a NodeRed flow in order to perform the calculations that determine how much power is available for the chargepoint based on a selected working mode (e.g. load with minimum current, peak shave, wait for solar, ā€¦).
I wrote a function in javascript to convert the current to the required register values for modbus, but your script is more elegant. Thanks for sharing!
Best regards,
Lieven.
Lotā€™s of information hereā€¦ will be useful in the future
Iā€™m looking into buying an Alfen Eve S-Line (with RFID reader).
I also want to read/control charging speed from HA.
But which license do I need to activate Modbus? is it the ā€˜Active loadbalancingā€™, or another one? (and can I buy it afterwards, or is this only possible for ā€˜installersā€™)
And maybe additional question for people having their ā€˜ownā€™ system (not managed by employer or other CPO):
Is it possible to get a list of charging sessions from the device itself, or is there a (free) OCPP backend from Alfen who can provide this?
Grtz
Hey @abertier
regarding the license: please see this post earlier in the thread: Alfen Eve Pro EV chargepoint interface via TCP modbus - #13 by hollie
You can buy this afterwards, but you need to go via the channel where you bought the charge station, you cannot buy it form Alfen directly (at least I could not when I started this thread).
Greetz,
Lieven
I just acquired an Alfa Eve Single S charging station with Load Balancing enabled. It is running firmware version 6.5.0-4217. Browsing through this excellent thread to identify how to connect the charging station to HA, I noticed a persistent conclusion, unless I have missed something, that concurrent use of load balancing with P1 serial connection and Modbus TCP/IP for monitoring purposes would not be possible.
However, using ACE Service installer I identified the following possible settings with
Active Load Balancing ENABLED. Data source selection possible between Meter; Meter + EMS Monitoring and Energy Management system. Protocol selection possible between: Modbus TCP/IP; P1; Modbus RTU and TIC.
I assume that my requirement can be accomplished using the settings: ā€œ Meter + EMS Monitoringā€ as source and ā€œDSMR4.xā€ as protocol.
Unfortunately I canā€™t test this since my EV will not be delivered before March 2024.
Has anyone else used the above settings for the same objective? And could confirm validity?
I found this in the thread:
[leeyuentuen] my integration is not using modbus but using http polling system
So if I undertand correctly, you can use your P1 (DSMR) for active load balancing and use http requests with GitHub - leeyuentuen/alfen_wallbox: Alfen wallbox - Home Assistant Component to monitor.
@leeyuentuen am I correct?
This Custom integration may be an option but using P1 and HA built in modbus integration to monitor would suffice. Hence no need for separate custom integration unless their are parameters available in the custom integration which you canā€™t find in the modbus list https://alfen.com/file-download/download/public/1610
thatā€™s correct
I think it is easier to use the https implementation, this way DSMR is still working.
And if you want you can configure all the things via http as you did via modbus I thinkā€¦
Eve S-line is orderedā€¦ Thanks for the feedback and information in this thread !
Hi @hollie , lots of interesting stuff going on here, thanks!
I might have missed it, but in configuration.yaml I donā€™t see the entry for displaying the overall charge percentage when the car is charging.
Can you maybe point me how to accomplish this? I am still learning HA on the go.
Hey @ARTSRAY
the chargepoint does not have any indication of the charge percentage of the car battery. If you need that information you will need to get it via the API of your specific car.
Best regards,
Hollie
Sadly still the case. Almost a year now I am in conflict with my supplier as they arenā€™t providing it/selling it. And Alfen is no help in this at all. A crappy system to be honest.
So if you buy one, buy one with the license included. My workplace forgot and Iā€™m still dealing with it.
Hi there,
I managed already for long time to switch from 3 phase to 1 phase over modbus when I want to charge on solar, this to make maximum solar self consumption. Car is only charging on solar power from that moment.
But at sunset I want it to switch to 3 phase again and thereā€™s the problemā€¦
For some reason the Alfen refuses to go from 1 phase to 3 phase. Modbus says it has switched to three phase, but the power is not increasing so Iā€™m pretty sure that the Alfen is not allowing it to switch to 3 phase.
Itā€™s only when I stop the charging session and start a new one that my car is charging on 3 phase again.
So hereā€™s the question (s):
  • Is there a possibility to reboot the charging station via modbus?
  • Is there an option to start/stop my charging session via an alternative way, so I can incorporate it in my automation perhaps?
  • Or anyone else who has experience with going from 1 phase to 3 phase in the same charging session?
