what would be the correct syntax for an alias for a shell_command, mentioned on https://home-assistant.io/components/shell_command/ unfortunately there;s no example ?
i have tried like this, bit this error out:
sw_tester_state_cl:
alias: Tester State (cl)
tester_state: >-
curl -X POST -d '{"seq":1, "method":"object_prop_get", "arguments":{"oid":"58ab8595", "prop":"state"}}' http://192.168.xxx.xxx/iungo/api_request
error:
Error running command:
OrderedDict([(‘alias’, ‘Tester State (cl)’), (‘tester_state’, ‘curl -X POST -d ‘{“seq”:1, “method”:“object_prop_get”, “arguments”:{“oid”:“58ab8595”, “prop”:“state”}}’ http://192.168.xxx.xxx8/iungo/api_request ’)]), return code: 2
Cheers,
Marius
RobDYI
February 26, 2018, 10:26pm
2
I haven’t had a need for alias on shell commands because I can’t show them on the front end. To execute them, I need to put them in a automation or template switch.
yes, i understand that, but since the documentation mentions an alias configurable option, i would like to know how…always easier to use a nice alias
The shell_command does nothing other than register a service. There is no component to give an alias to. When the docs talk about the alias then they can only be talking about the shell command name.
i.e. in the example
shell_command:
restart_pow: touch ~/.pow/restart.txt
Then restart_pow is the alias
ok thanks, I’ve changed accordingly, saves a lot of code…
maybe the docs should be updated to reflect that, and take out the alias bit, cause thats incorrect as is stands.
