Due to an issue with the SD Card i had to reimage my RaspberryMatic and restored the last backup which i do monthly.
Nothing changed inbetween on the Raspberrymatic.
The most parts are working properly (Sensors nad buttons) on HomeAssistant. But anytime i call a cover (HMIP-FROLL) to be closed or opened a error occurs: invalid literal for int() with base 10: ‘’
If i restart HA the service is working for a few sequences and then it is failing again and will continue to fail.
Logger: homeassistant.components.websocket_api.http.connection
Source: components/homematic/cover.py:51
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 18:24:16 (14 occurrences)
Last logged: 18:59:15
- [547312526864] invalid literal for int() with base 10: ‘’
- [547046173200] invalid literal for int() with base 10: ‘’
- [547013812176] invalid literal for int() with base 10: ‘’
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 205, in handle_call_service await hass.services.async_call( File “/usr/src/homeassistant/homeassistant/core.py”, line 1965, in async_call response_data = await coro ^^^^^^^^^^ File “/usr/src/homeassistant/homeassistant/core.py”, line 2005, in _execute_service return await cast( ^^^^^^^^^^^ File “/usr/src/homeassistant/homeassistant/helpers/entity_component.py”, line 235, in handle_service return await service.entity_service_call( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 806, in entity_service_call entity.supported_features is None ^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/src/homeassistant/homeassistant/components/cover/init.py”, line 303, in supported_features if self.current_cover_position is not None: ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/src/homeassistant/homeassistant/components/homematic/cover.py”, line 51, in current_cover_position return int(self._hm_get_state() * 100) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ValueError: invalid literal for int() with base 10: ‘’
First occurred: 18:23:32 (3 occurrences)
Last logged: 18:24:04
Error doing job: Exception in callback Entity.async_write_ha_state()
File “/usr/local/lib/python3.11/asyncio/events.py”, line 80, in _run
self._context.run(self._callback, *self._args)
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 742, in async_write_ha_state
self._async_write_ha_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 810, in _async_write_ha_state
state = self._stringify_state(available)
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 748, in _stringify_state
if (state := self.state) is None:
File “/usr/src/homeassistant/homeassistant/components/cover/init.py”, line 274, in state
if (closed := self.is_closed) is None:
File “/usr/src/homeassistant/homeassistant/components/homematic/cover.py”, line 64, in is_closed
