All devices unavailable after zwave 0.1.87
Hi All,
I have an 800 GPIO chip in HA yellow. After Zwave upgraded to 1.87 all my devices went to unavailable. I restored 1.86 and I still have no luck getting any of my devices back (zooz door sensors, water leak, and motion sensors). I have reset the zwave module and tried to start from the beginning. Now, it will not pick up any devices when in inclusion mode.
I used JS UI to do a hard reset and new keys, and still unable to add any devices.
Any idea or guidance on what I should try next?
Update 8/26:
I started a new HA instance with USB z-wave. It installed the 0.1.87 version. Still not able to connect any devices.
I tried by Full DSK code and was still not able to find the device when in inclusion mode. (I have factory reset all the sensors as well)
  1. Check your region. Try manually setting region even if it’s already set.
I did that as well. but I do see a USA Long Range…changing to that now
No luck changing to USA long-range
Tried with the default power settings
als[quote=“cornellrwilliams, post:2, topic:607058, full:true”]
    [/quote]
also, tried with 9.9 and 3.3
You’ve unplugged the stick and power cycled the computer?
Of course.
it is really odd that even this new instance of HA with a New USB stick is having the same issue.
