Literally all the devices become unavailable : sensors (battery powered), routers (like plug/siren/switch - continuously powered). I checked again today, I lost connection at 4:56pm then 7:41pm. It’s less than 6 hours then.
Here is the log for 4:56pm
2024-03-09 16:55:56.731 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame received getValue: [<EzspStatus.SUCCESS: 0>, b'\xf9']
2024-03-09 16:55:56.734 DEBUG (MainThread) [bellows.zigbee.application] Free buffers status EzspStatus.SUCCESS, value: 249
2024-03-09 16:55:56.735 DEBUG (MainThread) [bellows.zigbee.application] ezsp_counters: [MAC_RX_BROADCAST = 2901, MAC_TX_BROADCAST = 640, MAC_RX_UNICAST = 3911, MAC_TX_UNICAST_SUCCESS = 1494, MAC_TX_UNICAST_RETRY = 149, MAC_TX_UNICAST_FAILED = 31, APS_DATA_RX_BROADCAST = 2, APS_DATA_TX_BROADCAST = 2, APS_DATA_RX_UNICAST = 2636, APS_DATA_TX_UNICAST_SUCCESS = 1226, APS_DATA_TX_UNICAST_RETRY = 38, APS_DATA_TX_UNICAST_FAILED = 13, ROUTE_DISCOVERY_INITIATED = 24, NEIGHBOR_ADDED = 6, NEIGHBOR_REMOVED = 0, NEIGHBOR_STALE = 25, JOIN_INDICATION = 0, CHILD_REMOVED = 0, ASH_OVERFLOW_ERROR = 0, ASH_FRAMING_ERROR = 0, ASH_OVERRUN_ERROR = 0, NWK_FRAME_COUNTER_FAILURE = 0, APS_FRAME_COUNTER_FAILURE = 0, UTILITY = 0, APS_LINK_KEY_NOT_AUTHORIZED = 0, NWK_DECRYPTION_FAILURE = 0, APS_DECRYPTION_FAILURE = 0, ALLOCATE_PACKET_BUFFER_FAILURE = 0, RELAYED_UNICAST = 0, PHY_TO_MAC_QUEUE_LIMIT_REACHED = 0, PACKET_VALIDATE_LIBRARY_DROPPED_COUNT = 0, TYPE_NWK_RETRY_OVERFLOW = 0, PHY_CCA_FAIL_COUNT = 0, BROADCAST_TABLE_FULL = 0, PTA_LO_PRI_REQUESTED = 0, PTA_HI_PRI_REQUESTED = 0, PTA_LO_PRI_DENIED = 0, PTA_HI_PRI_DENIED = 0, PTA_LO_PRI_TX_ABORTED = 0, PTA_HI_PRI_TX_ABORTED = 0, ADDRESS_CONFLICT_SENT = 0, EZSP_FREE_BUFFERS = 249]
2024-03-09 16:56:23.358 DEBUG (bellows.thread_0) [bellows.uart] Data frame: b'5541b1a9112a15b658964e24ab5592499cdf531210db9874f5de1583fc7e16e2ecd4e17e'
2024-03-09 16:56:23.359 DEBUG (bellows.thread_0) [bellows.uart] Sending: b'8610be7e'
2024-03-09 16:56:23.369 DEBUG (bellows.thread_0) [bellows.uart] Data frame: b'5d41b1a9112a15b658964e24ab5592499cdf531210db9874f5de1583fc7e16e2ecfa857e'
2024-03-09 16:56:23.369 DEBUG (bellows.thread_0) [bellows.uart] Sending: b'8610be7e'
2024-03-09 16:56:23.370 DEBUG (bellows.thread_0) [bellows.uart] Data frame: b'5d41b1a9112a15b658964e24ab5592499cdf531210db9874f5de1583fc7e16e2ecfa857e'
2024-03-09 16:56:23.370 DEBUG (bellows.thread_0) [bellows.uart] Sending: b'8610be7e'
2024-03-09 16:56:23.371 DEBUG (bellows.thread_0) [bellows.uart] Sending: b'8610be7e'
2024-03-09 16:56:23.380 DEBUG (bellows.thread_0) [bellows.uart] Data frame: b'6541b1a9112a15b658904124ab5593499c81431e26679874f5de8483f37b1ec7e255667e'
2024-03-09 16:56:23.381 DEBUG (bellows.thread_0) [bellows.uart] Sending: b'87009f7e'
2024-03-09 16:56:23.383 DEBUG (bellows.thread_0) [bellows.uart] Error code: ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT, Version: 2, frame: b'c20251a8bd7e'
2024-03-09 16:56:23.384 DEBUG (bellows.thread_0) [bellows.uart] Data frame: b'7541b1a9112a15b658904124ab5593499c9e7f1926679874f5de6383f37b1ecde2a2bd7e'
2024-03-09 16:56:23.384 DEBUG (bellows.thread_0) [bellows.uart] Sending: b'8070787e'
2024-03-09 16:56:23.392 DEBUG (bellows.thread_0) [bellows.uart] Error code: ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT, Version: 2, frame: b'c20251a8bd7e'
2024-03-09 16:56:23.393 DEBUG (bellows.thread_0) [bellows.uart] Error code: ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT, Version: 2, frame: b'c20251a8bd7e'
2024-03-09 16:56:23.398 DEBUG (bellows.thread_0) [bellows.uart] Error code: ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT, Version: 2, frame: b'c20251a8bd7e'
2024-03-09 16:56:23.420 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame received incomingMessageHandler: [<EmberIncomingMessageType.INCOMING_UNICAST: 0>, EmberApsFrame(profileId=260, clusterId=1026, sourceEndpoint=1, destinationEndpoint=1, options=<EmberApsOption.APS_OPTION_NONE: 0>, groupId=0, sequence=145), 116, -71, 0x15fd, 255, 255, b'\x18v\n\x00\x00)E\x07']
2024-03-09 16:56:23.420 DEBUG (MainThread) [bellows.zigbee.application] Received incomingMessageHandler frame with [<EmberIncomingMessageType.INCOMING_UNICAST: 0>, EmberApsFrame(profileId=260, clusterId=1026, sourceEndpoint=1, destinationEndpoint=1, options=<EmberApsOption.APS_OPTION_NONE: 0>, groupId=0, sequence=145), 116, -71, 0x15fd, 255, 255, b'\x18v\n\x00\x00)E\x07']
2024-03-09 16:56:23.421 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2024, 3, 9, 15, 56, 23, 421413, tzinfo=datetime.timezone.utc), src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x15FD), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=145, profile_id=260, cluster_id=1026, data=Serialized[b'\x18v\n\x00\x00)E\x07'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=116, rssi=-71)
2024-03-09 16:56:23.423 DEBUG (MainThread) [zigpy.zcl] [0x15FD:1:0x0402] Received ZCL frame: b'\x18v\n\x00\x00)E\x07'
2024-03-09 16:56:23.424 DEBUG (MainThread) [zigpy.zcl] [0x15FD:1:0x0402] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl<0x18>(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Server_to_Client: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True), tsn=118, command_id=10, *direction=<Direction.Server_to_Client: 1>)
2024-03-09 16:56:23.426 DEBUG (MainThread) [zigpy.zcl] [0x15FD:1:0x0402] Decoded ZCL frame: TemperatureMeasurementCluster:Report_Attributes(attribute_reports=[Attribute(attrid=0x0000, value=TypeValue(type=int16s, value=1861))])
2024-03-09 16:56:23.426 DEBUG (MainThread) [zigpy.zcl] [0x15FD:1:0x0402] Received command 0x0A (TSN 118): Report_Attributes(attribute_reports=[Attribute(attrid=0x0000, value=TypeValue(type=int16s, value=1861))])
2024-03-09 16:56:23.427 DEBUG (MainThread) [zigpy.zcl] [0x15FD:1:0x0402] Attribute report received: measured_value=1861
2024-03-09 16:56:23.428 DEBUG (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0x15FD:1:0x0402]: cluster_handler[temperature] attribute_updated - cluster[Temperature Measurement] attr[measured_value] value[1861]
2024-03-09 16:56:23.430 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame received incomingMessageHandler: [<EmberIncomingMessageType.INCOMING_UNICAST: 0>, EmberApsFrame(profileId=260, clusterId=2820, sourceEndpoint=1, destinationEndpoint=1, options=<EmberApsOption.APS_OPTION_ENABLE_ROUTE_DISCOVERY: 256>, groupId=0, sequence=207), 100, -75, 0xa9cb, 255, 255, b'\x18\xe7\n\x0f\x05!`\t']
2024-03-09 16:56:23.430 DEBUG (MainThread) [bellows.zigbee.application] Received incomingMessageHandler frame with [<EmberIncomingMessageType.INCOMING_UNICAST: 0>, EmberApsFrame(profileId=260, clusterId=2820, sourceEndpoint=1, destinationEndpoint=1, options=<EmberApsOption.APS_OPTION_ENABLE_ROUTE_DISCOVERY: 256>, groupId=0, sequence=207), 100, -75, 0xa9cb, 255, 255, b'\x18\xe7\n\x0f\x05!`\t']
2024-03-09 16:56:23.431 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2024, 3, 9, 15, 56, 23, 431404, tzinfo=datetime.timezone.utc), src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xA9CB), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=207, profile_id=260, cluster_id=2820, data=Serialized[b'\x18\xe7\n\x0f\x05!`\t'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=100, rssi=-75)
2024-03-09 16:56:23.433 DEBUG (MainThread) [zigpy.zcl] [0xA9CB:1:0x0b04] Received ZCL frame: b'\x18\xe7\n\x0f\x05!`\t'
2024-03-09 16:56:23.435 DEBUG (MainThread) [zigpy.zcl] [0xA9CB:1:0x0b04] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl<0x18>(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Server_to_Client: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True), tsn=231, command_id=10, *direction=<Direction.Server_to_Client: 1>)
2024-03-09 16:56:23.437 DEBUG (MainThread) [zigpy.zcl] [0xA9CB:1:0x0b04] Decoded ZCL frame: ElectricalMeasurement:Report_Attributes(attribute_reports=[Attribute(attrid=0x050F, value=TypeValue(type=uint16_t, value=2400))])
2024-03-09 16:56:23.438 DEBUG (MainThread) [zigpy.zcl] [0xA9CB:1:0x0b04] Received command 0x0A (TSN 231): Report_Attributes(attribute_reports=[Attribute(attrid=0x050F, value=TypeValue(type=uint16_t, value=2400))])
2024-03-09 16:56:23.439 DEBUG (MainThread) [zigpy.zcl] [0xA9CB:1:0x0b04] Attribute report received: apparent_power=2400
2024-03-09 16:56:23.453 DEBUG (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xA9CB:1:0x0b04]: cluster_handler[electrical_measurement] attribute_updated - cluster[Electrical Measurement] attr[apparent_power] value[2400]
2024-03-09 16:56:23.457 ERROR (MainThread) [bellows.ezsp] NCP entered failed state. Requesting APP controller restart
2024-03-09 16:56:23.457 DEBUG (MainThread) [bellows.zigbee.application] Received _reset_controller_application frame with (<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>,)
2024-03-09 16:56:23.458 DEBUG (MainThread) [zigpy.application] Connection to the radio has been lost: <NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>
2024-03-09 16:56:23.468 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] Connection to the radio was lost: <NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>
2024-03-09 16:56:23.469 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame received incomingMessageHandler: [<EmberIncomingMessageType.INCOMING_UNICAST: 0>, EmberApsFrame(profileId=260, clusterId=2820, sourceEndpoint=1, destinationEndpoint=1, options=<EmberApsOption.APS_OPTION_ENABLE_ROUTE_DISCOVERY: 256>, groupId=0, sequence=208), 88, -78, 0xa9cb, 255, 255, b'\x18\x00\n\x0f\x05!j\t']
2024-03-09 16:56:23.469 DEBUG (MainThread) [bellows.zigbee.application] Received incomingMessageHandler frame with [<EmberIncomingMessageType.INCOMING_UNICAST: 0>, EmberApsFrame(profileId=260, clusterId=2820, sourceEndpoint=1, destinationEndpoint=1, options=<EmberApsOption.APS_OPTION_ENABLE_ROUTE_DISCOVERY: 256>, groupId=0, sequence=208), 88, -78, 0xa9cb, 255, 255, b'\x18\x00\n\x0f\x05!j\t']
2024-03-09 16:56:23.470 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2024, 3, 9, 15, 56, 23, 470249, tzinfo=datetime.timezone.utc), src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xA9CB), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=208, profile_id=260, cluster_id=2820, data=Serialized[b'\x18\x00\n\x0f\x05!j\t'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=88, rssi=-78)
2024-03-09 16:56:23.471 DEBUG (MainThread) [zigpy.zcl] [0xA9CB:1:0x0b04] Received ZCL frame: b'\x18\x00\n\x0f\x05!j\t'
2024-03-09 16:56:23.476 DEBUG (MainThread) [zigpy.zcl] [0xA9CB:1:0x0b04] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl<0x18>(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Server_to_Client: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True), tsn=0, command_id=10, *direction=<Direction.Server_to_Client: 1>)
2024-03-09 16:56:23.478 DEBUG (MainThread) [zigpy.zcl] [0xA9CB:1:0x0b04] Decoded ZCL frame: ElectricalMeasurement:Report_Attributes(attribute_reports=[Attribute(attrid=0x050F, value=TypeValue(type=uint16_t, value=2410))])
2024-03-09 16:56:23.479 DEBUG (MainThread) [zigpy.zcl] [0xA9CB:1:0x0b04] Received command 0x0A (TSN 0): Report_Attributes(attribute_reports=[Attribute(attrid=0x050F, value=TypeValue(type=uint16_t, value=2410))])
2024-03-09 16:56:23.479 DEBUG (MainThread) [zigpy.zcl] [0xA9CB:1:0x0b04] Attribute report received: apparent_power=2410
2024-03-09 16:56:23.480 DEBUG (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xA9CB:1:0x0b04]: cluster_handler[electrical_measurement] attribute_updated - cluster[Electrical Measurement] attr[apparent_power] value[2410]
2024-03-09 16:56:23.484 DEBUG (bellows.thread_0) [bellows.uart] Connection lost: None
2024-03-09 16:56:23.484 DEBUG (bellows.thread_0) [bellows.uart] Closed serial connection
2024-03-09 16:56:23.545 ERROR (MainThread) [bellows.ezsp] NCP entered failed state. Requesting APP controller restart
2024-03-09 16:56:23.545 DEBUG (MainThread) [bellows.zigbee.application] Received _reset_controller_application frame with (<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>,)
2024-03-09 16:56:23.546 DEBUG (MainThread) [zigpy.application] Connection to the radio has been lost: <NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>
2024-03-09 16:56:23.546 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] Connection to the radio was lost: <NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>
2024-03-09 16:56:23.546 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] Ignoring reset, one is already running
2024-03-09 16:56:23.546 ERROR (MainThread) [bellows.ezsp] NCP entered failed state. Requesting APP controller restart
2024-03-09 16:56:23.546 DEBUG (MainThread) [bellows.zigbee.application] Received _reset_controller_application frame with (<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>,)
2024-03-09 16:56:23.547 DEBUG (MainThread) [zigpy.application] Connection to the radio has been lost: <NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>
2024-03-09 16:56:23.547 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] Connection to the radio was lost: <NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>
2024-03-09 16:56:23.547 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] Ignoring reset, one is already running
2024-03-09 16:56:23.547 ERROR (MainThread) [bellows.ezsp] NCP entered failed state. Requesting APP controller restart
2024-03-09 16:56:23.548 DEBUG (MainThread) [bellows.zigbee.application] Received _reset_controller_application frame with (<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>,)
2024-03-09 16:56:23.548 DEBUG (MainThread) [zigpy.application] Connection to the radio has been lost: <NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>
2024-03-09 16:56:23.548 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] Connection to the radio was lost: <NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>
2024-03-09 16:56:23.549 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] Ignoring reset, one is already running
2024-03-09 16:56:23.549 ERROR (MainThread) [bellows.ezsp] NCP entered failed state. Requesting APP controller restart
2024-03-09 16:56:23.549 DEBUG (MainThread) [bellows.zigbee.application] Received _reset_controller_application frame with (<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>,)
2024-03-09 16:56:23.550 DEBUG (MainThread) [zigpy.application] Connection to the radio has been lost: <NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>
2024-03-09 16:56:23.550 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] Connection to the radio was lost: <NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>
2024-03-09 16:56:23.550 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] Ignoring reset, one is already running
2024-03-09 16:56:23.550 ERROR (MainThread) [bellows.ezsp] NCP entered failed state. Requesting APP controller restart
2024-03-09 16:56:23.550 DEBUG (MainThread) [bellows.zigbee.application] Received _reset_controller_application frame with (<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>,)
2024-03-09 16:56:23.551 DEBUG (MainThread) [zigpy.application] Connection to the radio has been lost: <NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>
2024-03-09 16:56:23.551 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] Connection to the radio was lost: <NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>
2024-03-09 16:56:23.551 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] Ignoring reset, one is already running
2024-03-09 16:56:23.551 ERROR (MainThread) [bellows.ezsp] NCP entered failed state. Requesting APP controller restart
2024-03-09 16:56:23.551 DEBUG (MainThread) [bellows.zigbee.application] Received _reset_controller_application frame with (<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>,)
2024-03-09 16:56:23.552 DEBUG (MainThread) [zigpy.application] Connection to the radio has been lost: <NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>
2024-03-09 16:56:23.552 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] Connection to the radio was lost: <NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>
2024-03-09 16:56:23.552 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] Ignoring reset, one is already running
2024-03-09 16:56:23.559 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x6857](Plug 01): last_seen is 4043085.28486681 seconds ago and ping attempts have been exhausted, marking the device unavailable
2024-03-09 16:56:23.559 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x6857](Plug 01): Update device availability - device available: False - new availability: False - changed: False
2024-03-09 16:56:23.560 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x4340](01MINIZB): Device seen - marking the device available and resetting counter
2024-03-09 16:56:23.560 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x4340](01MINIZB): Update device availability - device available: True - new availability: True - changed: False
2024-03-09 16:56:23.561 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x9153](FYRTUR block-out roller blind): Device seen - marking the device available and resetting counter
2024-03-09 16:56:23.561 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x9153](FYRTUR block-out roller blind): Update device availability - device available: True - new availability: True - changed: False
2024-03-09 16:56:23.608 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0xA9CB](ZLinky_TIC): Device seen - marking the device available and resetting counter
2024-03-09 16:56:23.609 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0xA9CB](ZLinky_TIC): Update device availability - device available: True - new availability: True - changed: False
2024-03-09 16:56:23.668 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0xAD7B](lumi.sensor_wleak.aq1): Device seen - marking the device available and resetting counter
2024-03-09 16:56:23.669 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0xAD7B](lumi.sensor_wleak.aq1): Update device availability - device available: True - new availability: True - changed: False
2024-03-09 16:56:23.670 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x4274](lumi.vibration.aq1): last_seen is 4074561.704456806 seconds ago and ping attempts have been exhausted, marking the device unavailable
2024-03-09 16:56:23.670 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x4274](lumi.vibration.aq1): Update device availability - device available: False - new availability: False - changed: False
2024-03-09 16:56:23.675 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x2F8D](lumi.vibration.aq1): Device seen - marking the device available and resetting counter
2024-03-09 16:56:23.675 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x2F8D](lumi.vibration.aq1): Update device availability - device available: True - new availability: True - changed: False
2024-03-09 16:56:23.676 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x335B](lumi.sensor_magnet.aq2): Device seen - marking the device available and resetting counter
2024-03-09 16:56:23.677 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x335B](lumi.sensor_magnet.aq2): Update device availability - device available: True - new availability: True - changed: False
