All devices went offline in My Esphome add-on ( Hassio 0.103.3 Ubuntu 18.04.3 LTS)
Log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: ESPHome
ESPHome Hass.io add-on for intelligently managing all your ESP8266/ESP32 devices.
Add-on version: 1.13.6
You are running the latest version of this add-on.
System: Ubuntu 18.04.3 LTS (amd64 / qemux86-64)
Home Assistant version: 0.103.3
Supervisor version: 193
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 10-requirements.sh: executing...
[cont-init.d] 10-requirements.sh: exited 0.
[cont-init.d] 20-nginx.sh: executing...
[cont-init.d] 20-nginx.sh: exited 0.
[cont-init.d] 30-esphome.sh: executing...
[cont-init.d] 30-esphome.sh: exited 0.
[cont-init.d] 40-migrate.sh: executing...
[cont-init.d] 40-migrate.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[19:52:51] INFO: Waiting for dashboard to come up...
[services.d] done.
[19:52:51] INFO: Starting ESPHome dashboard...
INFO Starting dashboard web server on unix socket /var/run/esphome.sock and configuration dir /config/esphome...
[19:52:52] INFO: Starting NGINX...
INFO 200 GET / (0.0.0.0) 12.98ms
INFO 101 GET /ace (0.0.0.0) 0.56ms
INFO Running command 'esphome --dashboard -q /config/esphome vscode --ace'
INFO 304 GET /edit?configuration=led_strip.yaml (0.0.0.0) 1.31ms
INFO 302 POST /wizard.html (0.0.0.0) 2.18ms
INFO 200 GET /?begin=True (0.0.0.0) 1.97ms
INFO 101 GET /ace (0.0.0.0) 0.51ms
INFO 101 GET /validate (0.0.0.0) 0.63ms
INFO Running command 'esphome --dashboard /config/esphome/we.yaml config'
INFO Process exited with return code 0
INFO 200 GET / (0.0.0.0) 5.20ms
INFO 101 GET /ace (0.0.0.0) 0.73ms
INFO 304 GET /edit?configuration=led_strip.yaml (0.0.0.0) 1.99ms
INFO 304 GET /edit?configuration=led_strip.yaml (0.0.0.0) 0.58ms
INFO 200 GET /edit?configuration=we.yaml (0.0.0.0) 1.49ms
INFO 200 POST /edit?configuration=we.yaml (0.0.0.0) 3.07ms
INFO 101 GET /upload (0.0.0.0) 0.41ms
INFO Running command 'esphome --dashboard /config/esphome/we.yaml run --upload-port OTA'
INFO 200 POST /edit?configuration=we.yaml (0.0.0.0) 1.81ms
INFO 200 GET /edit?configuration=we.yaml (0.0.0.0) 0.40ms
INFO 101 GET /compile (0.0.0.0) 0.61ms
INFO Running command 'esphome --dashboard /config/esphome/we.yaml compile'
INFO 200 GET /download.bin?configuration=we.yaml (0.0.0.0) 3.63ms
INFO 101 GET /logs (0.0.0.0) 0.86ms
INFO Running command 'esphome --dashboard /config/esphome/door_bell.yaml logs --serial-port OTA'
INFO 200 GET / (0.0.0.0) 6.85ms
INFO 101 GET /ace (0.0.0.0) 1.69ms
INFO 304 GET / (0.0.0.0) 4.49ms
INFO 101 GET /ace (0.0.0.0) 0.41ms
INFO 304 GET / (0.0.0.0) 4.21ms
INFO 101 GET /ace (0.0.0.0) 1.85ms
INFO 101 GET /ace (0.0.0.0) 0.42ms
INFO 200 GET / (0.0.0.0) 5.97ms
INFO 101 GET /ace (0.0.0.0) 0.33ms
INFO 304 GET / (0.0.0.0) 4.53ms
INFO 101 GET /ace (0.0.0.0) 1.93ms
INFO 304 GET / (0.0.0.0) 3.87ms
INFO 101 GET /ace (0.0.0.0) 1.97ms
