Full logs:
2022-08-15 03:02:15.947 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘Quarto Principal’ for apple_tv integration not ready yet: Not found at 192.168.0.35, waiting for discovery; Retrying in background
2022-08-15 03:02:15.949 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘Color 0x531d6fb’ for yeelight integration not ready yet: Failed to read from the socket at 192.168.0.198:55443: [Errno 111] Connect call failed (‘192.168.0.198’, 55443).; Retrying in background
2022-08-15 03:02:16.114 WARNING (MainThread) [homeassistant.components.dlna_dms] Failed connecting to recently alive device at http://192.168.0.100:32469/DeviceDescription.xml: UpnpConnectionError(‘ClientConnectorError(ConnectionKey(host=‘192.168.0.100’, port=32469, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-8625894658308676900), ConnectionRefusedError(111, “Connect call failed (‘192.168.0.100’, 32469)”))’, None)
2022-08-15 03:02:16.371 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can’t connect to ESPHome API for athom-smart-plug-02b14d @ 192.168.0.250: Error connecting to (‘192.168.0.250’, 6053): [Errno 111] Connect call failed (‘192.168.0.250’, 6053)
2022-08-15 03:02:16.390 ERROR (Thread-5) [pychromecast.socket_client] [Quarto principal(192.168.0.236):8009] Failed to connect to service ServiceInfo(type=‘mdns’, data=‘google-nest-hub-dd56ce902b54f623dae2ece1eb051780._googlecast._tcp.local.’), retrying in 5.0s
2022-08-15 03:02:16.943 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘Color 0x531d6fb’ for yeelight integration not ready yet: Failed to read from the socket at 192.168.0.198:55443: [Errno 111] Connect call failed (‘192.168.0.198’, 55443).; Retrying in background
2022-08-15 03:02:20.032 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘PC Escritorio HS110(EU)’ for tplink integration not ready yet: Unable to connect to the device: 192.168.0.152: [Errno 111] Connect call failed (‘192.168.0.152’, 9999); Retrying in background
2022-08-15 03:02:20.034 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘LED 3 KL50(UN)’ for tplink integration not ready yet: Unable to connect to the device: 192.168.0.60: [Errno 111] Connect call failed (‘192.168.0.60’, 9999); Retrying in background
2022-08-15 03:02:22.154 WARNING (MainThread) [aioshelly.block_device] device 192.168.0.19 initialize error - ClientConnectorError(ConnectionKey(host=‘192.168.0.19’, port=80, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-8625894658308676900), ConnectionRefusedError(111, “Connect call failed (‘192.168.0.19’, 80)”))
2022-08-15 03:02:24.448 WARNING (MainThread) [zigpy_znp.zigbee.application] Your network is using the insecure Zigbee2MQTT network key!
2022-08-15 03:02:24.624 ERROR (MainThread) [pyatv.protocols.airplay] Failed to set up remote control channel
2022-08-15 03:03:47.165 WARNING (MainThread) [aioshelly.block_device] device 192.168.0.19 initialize error - ClientConnectorError(ConnectionKey(host=‘192.168.0.19’, port=80, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-8625894658308676900), ConnectionRefusedError(111, “Connect call failed (‘192.168.0.19’, 80)”))
2022-08-15 03:04:00.169 WARNING (MainThread) [aioshelly.block_device] device 192.168.0.19 initialize error - ClientConnectorError(ConnectionKey(host=‘192.168.0.19’, port=80, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-8625894658308676900), ConnectionRefusedError(111, “Connect call failed (‘192.168.0.19’, 80)”))
2022-08-15 03:04:15.170 WARNING (MainThread) [aioshelly.block_device] device 192.168.0.19 initialize error - ClientConnectorError(ConnectionKey(host=‘192.168.0.19’, port=80, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-8625894658308676900), ConnectionRefusedError(111, “Connect call failed (‘192.168.0.19’, 80)”))
2022-08-15 03:04:24.159 WARNING (MainThread) [aioshelly.block_device] device 192.168.0.19 initialize error - ClientConnectorError(ConnectionKey(host=‘192.168.0.19’, port=80, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-8625894658308676900), ConnectionRefusedError(111, “Connect call failed (‘192.168.0.19’, 80)”))
2022-08-15 03:04:26.154 WARNING (MainThread) [aioshelly.block_device] device 192.168.0.19 initialize error - ClientConnectorError(ConnectionKey(host=‘192.168.0.19’, port=80, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-8625894658308676900), ConnectionRefusedError(111, “Connect call failed (‘192.168.0.19’, 80)”))
2022-08-15 03:04:28.165 WARNING (MainThread) [aioshelly.block_device] device 192.168.0.19 initialize error - ClientConnectorError(ConnectionKey(host=‘192.168.0.19’, port=80, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-8625894658308676900), ConnectionRefusedError(111, “Connect call failed (‘192.168.0.19’, 80)”))
2022-08-15 03:04:32.159 WARNING (MainThread) [aioshelly.block_device] device 192.168.0.19 initialize error - ClientConnectorError(ConnectionKey(host=‘192.168.0.19’, port=80, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-8625894658308676900), ConnectionRefusedError(111, “Connect call failed (‘192.168.0.19’, 80)”))
2022-08-15 03:04:44.157 WARNING (MainThread) [aioshelly.block_device] device 192.168.0.19 initialize error - ClientConnectorError(ConnectionKey(host=‘192.168.0.19’, port=80, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-8625894658308676900), ConnectionRefusedError(111, “Connect call failed (‘192.168.0.19’, 80)”))
2022-08-15 03:04:48.160 WARNING (MainThread) [aioshelly.block_device] device 192.168.0.19 initialize error - ClientConnectorError(ConnectionKey(host=‘192.168.0.19’, port=80, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-8625894658308676900), ConnectionRefusedError(111, “Connect call failed (‘192.168.0.19’, 80)”))
2022-08-15 03:04:51.159 WARNING (MainThread) [aioshelly.block_device] device 192.168.0.19 initialize error - ClientConnectorError(ConnectionKey(host=‘192.168.0.19’, port=80, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-8625894658308676900), ConnectionRefusedError(111, “Connect call failed (‘192.168.0.19’, 80)”))
2022-08-15 03:04:58.156 WARNING (MainThread) [aioshelly.block_device] device 192.168.0.19 initialize error - ClientConnectorError(ConnectionKey(host=‘192.168.0.19’, port=80, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-8625894658308676900), ConnectionRefusedError(111, “Connect call failed (‘192.168.0.19’, 80)”))
2022-08-15 03:05:00.156 WARNING (MainThread) [aioshelly.block_device] device 192.168.0.19 initialize error - ClientConnectorError(ConnectionKey(host=‘192.168.0.19’, port=80, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-8625894658308676900), ConnectionRefusedError(111, “Connect call failed (‘192.168.0.19’, 80)”))
2022-08-15 03:05:00.948 ERROR (MainThread) [pyatv.protocols.airplay] Failed to set up remote control channel
