All entities in Automation timeline showing as <unknown entity>
When I look at the Trace Timeline on any automation all my entities show as . The automation runs fine and I can’t see references to unknown entity anywhere else? Has anyone else seen this?
I have the same ‘problem’. Trace timeline shows entities as unknown, but automation runs fine.
I have the same issue - automations all run fine - but when viewing traces shows all entities as unknown entity. Did you find a solution to this?
I never found a solution and it’s definitely still happening and the automation is still working fine :frowning:
It just makes debugging harder
I have this in every trace .
Either all entities are unknown ( but run fine ) or entities are listed preceded by ‘unknown entity ‘ . I assumed a bug in trace …
