I just woke up to my Home assistant not showing the history graphs properly after a certain time tonight
Some examples
my versions
Some examples
my versions
What are you expecting, exactly?
That someone tells you to check the log? Consider it done.
See the “recorder backlog queue” error, it’s the one related to your issue.
Maybe DB corruption, maybe disk full, …
how do I know that the problem is? I have 35GB available so the SD card is not full
This had started working again after restart; tonight it stopped working again
some errors in the core log
Error doing job: Exception in callback SerialTransport._call_connection_lost(SerialExcepti...eset by peer'))
2:27:03 AM – (ERROR) util/async_.py - message first occurred at May 18, 2023 at 12:55:06 PM and shows up 11 times
Watchdog heartbeat timeout:
2:27:03 AM – (WARNING) /usr/local/lib/python3.9/site-packages/bellows/zigbee/application.py - message first occurred at May 18, 2023 at 12:54:29 PM and shows up 42 times
Timeout fetching ShellyVintage-3494546EFD6D data
2:26:19 AM – (ERROR) Shelly - message first occurred at May 18, 2023 at 12:55:07 PM and shows up 44 times
Logger: homeassistant.components.shelly
Source: helpers/update_coordinator.py:197
Integration: Shelly (documentation, issues)
First occurred: May 18, 2023 at 12:55:07 PM (44 occurrences)
Last logged: 2:26:19 AM
Logger: bellows.zigbee.application
Source: /usr/local/lib/python3.9/site-packages/bellows/zigbee/application.py:735
First occurred: May 18, 2023 at 12:54:29 PM (42 occurrences)
Last logged: 2:27:03 AM
Watchdog heartbeat timeout: EZSP is not running
Source: util/async_.py:135
First occurred: May 18, 2023 at 12:55:06 PM (11 occurrences)
Error doing job: Exception in callback SerialTransport._call_connection_lost(SerialExcepti...disconnected'))
Error doing job: Exception in callback SerialTransport._call_connection_lost(None)
File "/usr/local/lib/python3.9/asyncio/events.py", line 80, in _run
self._context.run(self._callback, *self._args)
File "/usr/local/lib/python3.9/site-packages/serial_asyncio/__init__.py", line 417, in _call_connection_lost
self._serial.close()
File "/usr/local/lib/python3.9/site-packages/serial/urlhandler/protocol_socket.py", line 104, in close
time.sleep(0.3)
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 173, in protected_loop_func
check_loop(func, strict=strict)
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 135, in check_loop
raise RuntimeError(
RuntimeError: Detected blocking call to sleep inside the event loop. This is causing stability issues. Please report issue
following as have the same.
