Hass.io has been running for a couple of months without a problem. After a power outage, it wouldn’t come up on http or ssh but was pinging. I was able to access the low level ssh on 22222 though. Running ‘journalctl -f’ I could see a ton of files being moved into lost and found. Finally I get:
hassio start-resin-supervisor[27843]: Error: No such object: homeassistant/armhf-hassio-supervisor
hassio docker[27866]: Error response from daemon: No such container: resin_supervisor
‘docker ps’ shows nothing running
Found configuration.yaml here:
root@hassio:/mnt/data/lost+found/#16385/homeassistant#
Along with everything else I would expect.
If there anyway to restore from lost+found? Would that be enough to get the container(?) working again from docker (I’m well out of my depth here - apoligies if the terms are off!).
If not what would be the simplest way to recover some of these files before I wipe (I spent a while getting PS4-Waker to work).
Thanks in Advance
