Versions are Home Assistant 2022.11.4 and Frontend 20221108.0 - latest. I am running the home assistant container on a rpi 4. I enabled Advanced Mode and the container is running with privileged:true.
I’m sure that OP fixed this already, but I’m posting for everyone else. If you are looking for “All Hardware” the answer is to enable “Advanced Mode” when you go to your profile. Once you do that you will see all features such as USB, etc. *Please note if you are looking for the 3 dots they appear to no longer be present.
No joy here. I need to install a USB Zigbee dongle, but can’t find the “All hardware” menu under Hardware. It only shows Processor & Memory but no other option in advanced mode.
I tried adding “hardware:” to configuration.yaml, but didn’t help anything.
