I’ve upgraded the HA OS to 12.1 (still using HA Core 2024.1.6).
The problem is that all data history is a flat line. Sensors report properly and the automations work fine based on the data provided, but all graphs are a flat line that keeps changing with the sensor reported value like the current value persisted since the upgrade (see example below).
The strange part is also in the logs. E.g. the PIR sensors trigger properly and I see the state change in the logs but only until I refresh the page – as soon as I refresh the page, the PIR reported log disappears…
Thanks, – I found some entries - timestamps are from the backup restore time frame. Nothing from now:
2024-03-17 07:21:38.553 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2024-03-17 07:21:38.593 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=66 from 2024-02-15 16:11:53.632605)
Hi, I first attempted to fix the database, but it did not work. Then I deleted the .db file and rebooted the HA. The new .db file was created. Sensors still report the values, but nothing there’s not history info on the graphs. The db file is growing. No errors in the log now. Still no historical values …
Any other ideas? Thanks!
For the record: Layer 8 / human / user error – I have setup the recorder incorrectly. All fixed now. Thanks for attempting to help out, however I was looking in the wrong direction.
