All Hue & IKEA lamps stopped working - and only those!
I wanted to turn the light in my office on as usual, but it wouldn’t turn on. Analysis showed that all Hue and IKEA lamps & repeaters stopped working. All the other Zigbee devices work just fine.
Any idea what’s happening here?
Zigbee2MQTT:error 2023-08-13 19:15:55: Publish ‘set’ ‘state’ to ‘Tradfri Couch LI’ failed: ‘Error: Command 0xf4b3b1fffe62cd84/1 genOnOff.on({}, {“sendWhen”:“immediate”,“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:false,“direction”:0,“srcEndpoint”:null,“reservedBits”:0,“manufacturerCode”:null,“transactionSequenceNumber”:null,“writeUndiv”:false}) failed (Data request failed with error: ‘No network route’ (205))’
Zigbee2MQTT:error 2023-08-13 19:16:17: Failed to execute LQI for ‘IKEA Repeater Schuhraum’
Zigbee2MQTT:error 2023-08-13 19:16:43: Failed to execute LQI for ‘IKEA Repeater Wohnzimmer’
Zigbee2MQTT:error 2023-08-13 19:17:09: Failed to execute LQI for ‘IKEA Repeater Mara’
Zigbee2MQTT:error 2023-08-13 19:17:35: Failed to execute LQI for ‘TRADFRI AZ Schrank’
Zigbee2MQTT:error 2023-08-13 19:18:01: Failed to execute LQI for ‘Hue OG Flur’
Zigbee2MQTT:error 2023-08-13 19:18:27: Failed to execute LQI for ‘Hue AZ Schreibtisch’
Zigbee2MQTT:error 2023-08-13 19:18:53: Failed to execute LQI for ‘Hue AZ Deckenlampe’
A neighbour started a leaking microwave ?
Did you restart Zigbee2MQTT ?
The problem is limited to Hue devices, and hits all Hue devices.
Pretty sure it’s a software incompatibilty introduced by an update, but I can’t figure out where…
same issue here since HA update to core_2023.8.1 2 days ago.
currently on raspberry pi 4 (8GB)
Home Assistant 2023.8.2
Supervisor 2023.08.1
Operating System 10.4
Zigbee2MQTT Version: 1.32.2
Coordinator-Typ: zStack3x0
Coordinator-Version: 20221226
Sonoff_Zigbee_3.0_USB_Dongle_Plus
after reboot system everything works for a few minutes but then stops working. seems like HA is flooding the zigbee network. i can control entitys like lights through the web interface but cannot receive zigbee state from switches etc.
zigbee2mqtt logs show similar errors like on this thread above mentioned.
hers an example:
UPDATE: found out that for some reason my router assigned a new IP address to homeassistant raspi. i went in the router settings and did manually permanent assign the old IP it was working on for month and switched ha raspi off completely. after booting and reconnecting with the old IP assigned now everithing seems to work fine so far. still have no idea how and the above zigbee errors are related to the network IP or if i just had first bad luck after update and after switching off and starting again had better luck :))
