All in one or two Systems (Tabels, forms, messanger in HomeAssistant)
Hello
I’m working on a project to monitor a house and monitor greenhouses.
I could integrate ventilation, air conditioning, water parameters and all the things you need for a SmartHome very well in HomeAssistant.
However, I need tables, forms, etc. for various types of vegetables in order to be able to enter data here.
A kind of software for growing vegetables.
I am currently using my own software for this data. I have also integrated sensors for the greenhouses in this software.
Question:
Can you also create tables and forms in HomeAssistant?
Or does it make more sense to use two separate systems here?
I would also need all the databases for the greenhouse software in Home Assistant …
Thanks for your tips
Regards
Achim
You could create forms in HA for numeric data or pulldown fields for choices. Booleans for checkbox like choices. So yeah, in a way I think you could do pretty much everything. Tables though is difficult. You could use the grid layout options and some custom css to make it look like a spreadsheet or something alike. But it would be some work to make it so.
Is your software web based? You can put it in the ui via an iframe.
yes the software is webbased… yes a iframe is a simple way…
is ist possible to configure in Home Assistant also some mysql-querys ?
if yes, then i can also show and change some dates (like light on/off or some temp values)
then i use two systems… one of this is my webbased software
my thinking is now
if is possible to configure Home Assistant also with some mysql-querys … then i not need to connect and configure some sensors over Home Assistant.
The reason is my other webbased software— this software use a mysql-db to show on some changes like Temp-values or light on/off Times… and the arduinos write some sensor datas in this databse too…
now if is possible for home assistant to use some mysql-querys then is easy to integrate some dates from the greenhouse in the home-assistant frontend.
Then is maybe possible to show some dates from the greenhouses in homeasistant and also change some datas from there…
I don’t have then the full-control over both system by Home Assistant but maybe is this a way to integrated easy my running greenhouse system…with there databse
You can send MySQL query directly from HA. SQL - Home Assistant
