hi all
i stole a node red flow some time ago that gets all lights that are on and turns them off
i’d love to use this to auto change my lights brightness (only those that are on) when my home mode goes from day to evening. I have the trigger setup fine in teh full node but the sample below i am not sure of the format to pass the brightness through.
I’d greatly appreciate any advice.
thank you
[{"id":"f2677c379f9a1297","type":"ha-get-entities","z":"cf558353c0517902","name":"get lights that are on","server":"f9088194.9ff3a","version":0,"rules":[{"property":"entity_id","logic":"starts_with","value":"light.","valueType":"str"},{"property":"state","logic":"is","value":"on","valueType":"str"}],"output_type":"array","output_empty_results":false,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":1200,"y":360,"wires":[["11529c2a6313b4e9"]]},{"id":"11529c2a6313b4e9","type":"api-call-service","z":"cf558353c0517902","name":"evening brightness","server":"f9088194.9ff3a","version":5,"debugenabled":false,"domain":"light","service":"toggle","areaId":[],"deviceId":[],"entityId":[],"data":"{\"entity_id\": $join(\"brightness\":130,\"color_temp\":550.entity_id,\",\")}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1430,"y":360,"wires":[["3861a7f384cd3e86"]]},{"id":"f9088194.9ff3a","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
