I cannot access GUI on fresh Home Assistant Supervised installation
installation went absolutely OK:
sudo dpkg -i homeassistant-supervised.deb
(Reading database ... 145336 files and directories currently installed.)
Preparing to unpack homeassistant-supervised.deb ...
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
Leaving 'diversion of /etc/NetworkManager/NetworkManager.conf to /etc/NetworkManager/NetworkManager.conf.real by homeassistant-supervised'
Leaving 'diversion of /etc/NetworkManager/system-connections/default to /etc/NetworkManager/system-connections/default.real by homeassistant-supervised'
Leaving 'diversion of /etc/docker/daemon.json to /etc/docker/daemon.json.real by homeassistant-supervised'
Leaving 'diversion of /etc/network/interfaces to /etc/network/interfaces.real by homeassistant-supervised'
Unpacking homeassistant-supervised (1.0.2) over (1.0.2) ...
Setting up homeassistant-supervised (1.0.2) ...
[info] Restarting NetworkManager
[info] Restarting docker service
PING version.home-assistant.io (104.26.4.238) 56(84) bytes of data.
64 bytes from version.home-assistant.io (104.26.4.238): icmp_seq=1 ttl=57 time=126 ms
--- version.home-assistant.io ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 125.695/125.695/125.695/0.000 ms
[info] Install supervisor Docker container
[info] Install supervisor startup scripts
[info] Install AppArmor scripts
[info] Start Home Assistant Supervised
[info] Installing the 'ha' cli
docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
b036eff3dde1 ghcr.io/home-assistant/armv7-hassio-multicast:2021.04.0 "/init" 3 minutes ago Up 3 minutes hassio_multicast
7b9a9010acd6 ghcr.io/home-assistant/armv7-hassio-audio:2021.07.0 "/init" 3 minutes ago Up 3 minutes hassio_audio
880eab9ea82e ghcr.io/home-assistant/armv7-hassio-dns:2021.06.0 "/init" 3 minutes ago Up 3 minutes hassio_dns
d8763b233069 ghcr.io/home-assistant/armv7-hassio-cli:2021.09.0 "/init /bin/bash -c …" 3 minutes ago Up 3 minutes hassio_cli
50d9be6fbb3b ghcr.io/home-assistant/armv7-hassio-observer:2021.10.0 "/init" 5 hours ago Up 3 minutes 0.0.0.0:4357->80/tcp hassio_observer
f63f9f444788 homeassistant/armv7-hassio-supervisor "/init" 5 hours ago Up 3 minutes hassio_supervisor
but problem is that port 8123 is not opened and it is not listening
sudo netstat -tnlp | grep 8123
looks the Home Assistant is running too:
ha info
arch: aarch64
channel: stable
docker: 20.10.10
features:
- reboot
- shutdown
- services
- network
- hostname
- timedate
- os_agent
hassos: null
homeassistant: 2021.11.2
hostname: zipi
logging: info
machine: raspberrypi4-64
operating_system: Raspbian GNU/Linux 10 (buster)
state: running
supervisor: 2021.10.8
supported: false
supported_arch:
- aarch64
- armv7
- armhf
timezone: Europe/Paris
anyone can help to get home assistant started?
