Hi all, I have lots of custom cards that have been working fine for quite a while, and then suddenly after a restart today with no lovelace changes, they all became unavailable. Here’s what I get in the console… It’s hapening on many different types of devices and browsers. Any ideas what would cause this all of a sudden?
Loading module from “http://10.10.10.20:8123/customcards/mini-media-player-bundle.js” was blocked because of a disallowed MIME type (“text/plain”).
0
Loading module from “http://10.10.10.20:8123/customcards/custom-weather-card-chart.js” was blocked because of a disallowed MIME type (“text/plain”).
0
Loading module from “http://10.10.10.20:8123/customcards/custom_ui/calendar-card/calendar-card.js” was blocked because of a disallowed MIME type (“text/plain”).
0
Loading module from “http://10.10.10.20:8123/customcards/button-card.js” was blocked because of a disallowed MIME type (“text/plain”).
0
The script from “http://10.10.10.20:8123/customcards/air-visual-card.js” was loaded even though its MIME type (“text/plain”) is not a valid JavaScript MIME type.
0
The script from “http://10.10.10.20:8123/customcards/tracker-card.js” was loaded even though its MIME type (“text/plain”) is not a valid JavaScript MIME type.
0
Loading module from “http://10.10.10.20:8123/customcards/simple-thermostat.js” was blocked because of a disallowed MIME type (“text/plain”).
0
The script from “http://10.10.10.20:8123/customcards/vertical-stack-in-card.js” was loaded even though its MIME type (“text/plain”) is not a valid JavaScript MIME type.
0
Loading module from “http://10.10.10.20:8123/customcards/github/thomasloven/slider-entity-row.js?track=true” was blocked because of a disallowed MIME type (“text/plain”).
0
Loading failed for the module with source “http://10.10.10.20:8123/customcards/mini-media-player-bundle.js”. 0:1:1
Loading failed for the module with source “http://10.10.10.20:8123/customcards/custom_ui/calendar-card/calendar-card.js”. 0:1:1
Loading failed for the module with source “http://10.10.10.20:8123/customcards/button-card.js”. 0:1:1
Loading failed for the <script> with source “http://10.10.10.20:8123/customcards/air-visual-card.js”. 0:1:1
Loading failed for the module with source “http://10.10.10.20:8123/customcards/custom-weather-card-chart.js”. 0:1:1
The script from “http://10.10.10.20:8123/customcards/card-modder.js” was loaded even though its MIME type (“text/plain”) is not a valid JavaScript MIME type.
0
Loading failed for the <script> with source “http://10.10.10.20:8123/customcards/tracker-card.js”. 0:1:1
Loading failed for the module with source “http://10.10.10.20:8123/customcards/simple-thermostat.js”. 0:1:1
Loading failed for the <script> with source “http://10.10.10.20:8123/customcards/vertical-stack-in-card.js”. 0:1:1
Loading failed for the module with source “http://10.10.10.20:8123/customcards/github/thomasloven/slider-entity-row.js?track=true”. 0:1:1
The script from “http://10.10.10.20:8123/customcards/card-tools.js?track=true” was loaded even though its MIME type (“text/plain”) is not a valid JavaScript MIME type.
0
The script from “http://10.10.10.20:8123/customcards/github/thomasloven/layout-card.js?track=true” was loaded even though its MIME type (“text/plain”) is not a valid JavaScript MIME type.
0
The script from “http://10.10.10.20:8123/customcards/github/thomasloven/popup-card.js?track=true” was loaded even though its MIME type (“text/plain”) is not a valid JavaScript MIME type.
0
The script from “http://10.10.10.20:8123/customcards/github/thomasloven/browser-commander.js?track=true” was loaded even though its MIME type (“text/plain”) is not a valid JavaScript MIME type.
0
Loading failed for the <script> with source “http://10.10.10.20:8123/customcards/card-modder.js”. 0:1:1
Loading failed for the <script> with source “http://10.10.10.20:8123/customcards/card-tools.js?track=true”. 0:1:1
Loading failed for the <script> with source “http://10.10.10.20:8123/customcards/github/thomasloven/layout-card.js?track=true”. 0:1:1
Loading failed for the <script> with source “http://10.10.10.20:8123/customcards/github/thomasloven/popup-card.js?track=true”. 0:1:1
Loading failed for the <script> with source “http://10.10.10.20:8123/customcards/github/thomasloven/browser-commander.js?track=true”. 0:1:1
uncaught exception: http://10.10.10.20:8123/customcards/mini-media-player-bundle.js
uncaught exception: http://10.10.10.20:8123/customcards/custom_ui/calendar-card/calendar-card.js
uncaught exception: http://10.10.10.20:8123/customcards/button-card.js
uncaught exception: http://10.10.10.20:8123/customcards/air-visual-card.js
uncaught exception: http://10.10.10.20:8123/customcards/custom-weather-card-chart.js
uncaught exception: http://10.10.10.20:8123/customcards/tracker-card.js
uncaught exception: http://10.10.10.20:8123/customcards/simple-thermostat.js
uncaught exception: http://10.10.10.20:8123/customcards/vertical-stack-in-card.js
uncaught exception: http://10.10.10.20:8123/customcards/github/thomasloven/slider-entity-row.js?track=true
uncaught exception: http://10.10.10.20:8123/customcards/card-modder.js
uncaught exception: http://10.10.10.20:8123/customcards/card-tools.js?track=true
uncaught exception: http://10.10.10.20:8123/customcards/github/thomasloven/layout-card.js?track=true
uncaught exception: http://10.10.10.20:8123/customcards/github/thomasloven/popup-card.js?track=true
uncaught exception: http://10.10.10.20:8123/customcards/github/thomasloven/browser-commander.js?track=true
This site appears to use a scroll-linked positioning effect. This may not work well with asynchronous panning; see https://developer.mozilla.org/docs/Mozilla/Performance/ScrollLinkedEffects for further details and to join the discussion on related tools and features! 0
Source map error: TypeError: NetworkError when attempting to fetch resource.
Resource URL: moz-extension://8d7e8059-204b-f242-b6b0-8b7db69f9985/dist/content/index.js
Source Map URL: /content/index.js.map
