Hey All.
I’ve tried everything and have spend hours debugging with the best of my knowledge.
But the other day one of my (Pre-Flashed) Tasmota Smart Switches, just lost its settings, and I was able to recover its settings out back online.
OK no problem, but then I realized that now my other Tasmota devices are no longer seen by HS,
And even worse all of my 25 Tuya devices are not able to be found in HS
But for now I just would be truly grateful for some assistance on the Tasmota problem.
MQTT will not allow me to change it’s default settings. (See image). If I try to change the settings it will not save. Notice the broker that should be 192.168.0.xx, as well user name and password can’t be changed… and the password is like 50 characters long. again I can’t use the normal credentials. ?? Ughh
I deleted everything and now HS can find my 5 Tasmota Devices but can’t access or control them.
First I thought it was my PiHole DNS, but after some trouble shooting I think that’s ok.
SO I can directly control each Tasmota deices via their webpage, or through TasmoAdmin.
So I’m thinking its the MQTT settings?? But I’m at a loss as to what to do here…
Thanks in Advance…
Logger: homeassistant.components.mqtt.client
Source: components/mqtt/client.py:683
Integration: MQTT (documentation, issues)
First occurred: 12:58:24 PM (526 occurrences)
Last logged: 1:02:52 PM
No ACK from MQTT server in 10 seconds (mid: 383)
No ACK from MQTT server in 10 seconds (mid: 384)
No ACK from MQTT server in 10 seconds (mid: 385)
No ACK from MQTT server in 10 seconds (mid: 386)
No ACK from MQTT server in 10 seconds (mid: 1382)
