I’m running 2021.7.4 as a docker container on a QNAP NAS.
An Aeotec Gen5 Z-Stick is plugged into the device and mapped into the container.
HA still uses the “classic” zwave:
integration configured via configuration.yaml.
This has been working for years now.
Yesterday, I had to install a firmware update on the NAS and reboot it - not sure if the FW update is of any relevance here.
When HA came back up, I noticed that all my zwave.*
devices were (and still are) reported as Unavailable
- except for the Z-Stick, which is in Ready
state.
Most of the devices create some associated sensor.DEVICE
oder binary_sensor.DEVICE
entities which seem to be working ok - for example, I have an Aeotec Multisensor 6 in my kitchen named “aeotec_ms6_kitchen” and all the associated sensors like e.g. sensor.aeotec_ms6_kitchen_relative_humidity
report sensible values.
On the other hand, I also have a couple of Everspring Window sensors and their binary_sensor.everspring_sm103_door_window_sensor_sensor_N
entities are also shown as Unavailable
The log file does not reveal anything to me; there’s a lot of “complaining” about nodes that are not ready on HA startup, which I think is normal.
# grep homeassistant.components.zwave home-assistant.log
2021-07-29 21:30:04 INFO (MainThread) [homeassistant.components.zwave] Z-Wave USB path is /dev/ttyACM0
2021-07-29 21:30:07 INFO (MainThread) [homeassistant.components.zwave] Z-Wave network autoheal is enabled
2021-07-29 21:30:22 INFO (SyncWorker_1) [homeassistant.components.zwave] Starting Z-Wave network
2021-07-29 21:30:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 1 not ready after 30 seconds, continuing anyway
2021-07-29 21:30:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 2 not ready after 30 seconds, continuing anyway
2021-07-29 21:30:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 3 not ready after 30 seconds, continuing anyway
2021-07-29 21:30:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 4 not ready after 30 seconds, continuing anyway
2021-07-29 21:30:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 5 not ready after 30 seconds, continuing anyway
2021-07-29 21:30:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 6 not ready after 30 seconds, continuing anyway
2021-07-29 21:30:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 17 not ready after 30 seconds, continuing anyway
2021-07-29 21:30:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 23 not ready after 30 seconds, continuing anyway
2021-07-29 21:30:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 27 not ready after 30 seconds, continuing anyway
2021-07-29 21:30:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 28 not ready after 30 seconds, continuing anyway
2021-07-29 21:30:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 30 not ready after 30 seconds, continuing anyway
2021-07-29 21:30:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 31 not ready after 30 seconds, continuing anyway
2021-07-29 21:30:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 32 not ready after 30 seconds, continuing anyway
2021-07-29 21:30:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 33 not ready after 30 seconds, continuing anyway
2021-07-29 21:30:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 34 not ready after 30 seconds, continuing anyway
2021-07-29 21:31:24 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity AEON Labs ZW100 MultiSensor 6 Sensor (node_id: 28) ready after 1 seconds
2021-07-29 21:31:24 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity AEON Labs ZW100 MultiSensor 6 Sensor (node_id: 30) ready after 1 seconds
2021-07-29 21:31:25 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity AEON Labs ZW100 MultiSensor 6 Sensor (node_id: 31) ready after 2 seconds
2021-07-29 21:31:34 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity AEON Labs ZW100 MultiSensor 6 Battery Level (node_id: 28) ready after 11 seconds
2021-07-29 21:31:36 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity AEON Labs ZW100 MultiSensor 6 Battery Level (node_id: 30) ready after 13 seconds
2021-07-29 21:31:38 INFO (Dummy-11) [homeassistant.components.zwave] Z-Wave network is ready for use. All awake nodes have been queried. Sleeping nodes will be queried when they awake
2021-07-29 21:31:38 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity AEON Labs ZW100 MultiSensor 6 Battery Level (node_id: 31) ready after 15 seconds
2021-07-29 21:31:38 INFO (MainThread) [homeassistant.components.zwave] Z-Wave ready after 75 seconds
2021-07-29 21:31:38 INFO (SyncWorker_6) [homeassistant.components.zwave] Z-Wave polling interval set to 60000 ms
2021-07-29 21:31:44 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 32 Sensor (node_id: 32) not ready after 30 seconds, continuing anyway
2021-07-29 21:31:47 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 33 Sensor (node_id: 33) not ready after 30 seconds, continuing anyway
2021-07-29 21:31:49 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 34 Sensor (node_id: 34) not ready after 30 seconds, continuing anyway
2021-07-29 21:31:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 28 Alarm Type (node_id: 28) not ready after 30 seconds, continuing anyway
2021-07-29 21:31:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 28 Alarm Level (node_id: 28) not ready after 30 seconds, continuing anyway
2021-07-29 21:31:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 30 Alarm Type (node_id: 30) not ready after 30 seconds, continuing anyway
2021-07-29 21:31:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 30 Alarm Level (node_id: 30) not ready after 30 seconds, continuing anyway
2021-07-29 21:31:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 31 Alarm Type (node_id: 31) not ready after 30 seconds, continuing anyway
2021-07-29 21:31:53 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 31 Alarm Level (node_id: 31) not ready after 30 seconds, continuing anyway
2021-07-29 21:32:49 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity Danfoss Z Thermostat 014G0013 Battery Level (node_id: 2) ready after 1 seconds
2021-07-29 21:33:51 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity Danfoss Z Thermostat 014G0013 Battery Level (node_id: 6) ready after 1 seconds
2021-07-29 21:34:43 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity Danfoss Z Thermostat 014G0013 Battery Level (node_id: 5) ready after 1 seconds
2021-07-29 21:38:51 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity Danfoss Z Thermostat 014G0013 Battery Level (node_id: 3) ready after 1 seconds
2021-07-29 21:39:30 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity Everspring SM103 Door/Window Sensor Battery Level (node_id: 32) ready after 2 seconds
2021-07-29 21:39:58 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 32 Alarm Type (node_id: 32) not ready after 30 seconds, continuing anyway
2021-07-29 21:39:58 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 32 Alarm Level (node_id: 32) not ready after 30 seconds, continuing anyway
2021-07-29 21:43:47 INFO (SyncWorker_0) [homeassistant.components.zwave] Z-Wave test_network have been initialized
2021-07-29 22:00:00 INFO (SyncWorker_7) [homeassistant.components.zwave] Z-Wave heal running
2021-07-29 23:16:09 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity FIBARO System FGK10x Door Opening Sensor Sensor (node_id: 23) ready after 3 seconds
2021-07-29 23:16:10 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity FIBARO System FGK10x Door Opening Sensor Battery Level (node_id: 23) ready after 4 seconds
2021-07-29 23:16:10 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity FIBARO System FGK10x Door Opening Sensor Alarm Type (node_id: 23) ready after 4 seconds
2021-07-29 23:16:10 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity FIBARO System FGK10x Door Opening Sensor Alarm Level (node_id: 23) ready after 4 seconds
2021-07-29 23:49:07 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity FIBARO System FGMS001-ZW5 Motion Sensor Sensor (node_id: 17) ready after 1 seconds
2021-07-29 23:49:10 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity FIBARO System FGMS001-ZW5 Motion Sensor Battery Level (node_id: 17) ready after 4 seconds
2021-07-29 23:49:10 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity FIBARO System FGMS001-ZW5 Motion Sensor Alarm Type (node_id: 17) ready after 4 seconds
2021-07-29 23:49:10 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity FIBARO System FGMS001-ZW5 Motion Sensor Alarm Level (node_id: 17) ready after 4 seconds
2021-07-30 01:13:14 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity Everspring SM103 Door/Window Sensor Battery Level (node_id: 34) ready after 2 seconds
2021-07-30 01:13:42 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 34 Alarm Type (node_id: 34) not ready after 30 seconds, continuing anyway
2021-07-30 01:13:42 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 34 Alarm Level (node_id: 34) not ready after 30 seconds, continuing anyway
2021-07-30 10:04:34 INFO (Dummy-11) [homeassistant.components.zwave] Z-Wave network is complete. All nodes on the network have been queried
2021-07-30 10:04:35 INFO (MainThread) [homeassistant.components.zwave] Z-Wave entity Everspring SM103 Door/Window Sensor Battery Level (node_id: 33) ready after 2 seconds
2021-07-30 10:05:03 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 33 Alarm Type (node_id: 33) not ready after 30 seconds, continuing anyway
2021-07-30 10:05:03 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 33 Alarm Level (node_id: 33) not ready after 30 seconds, continuing anyway
Does anyone have an idea what’s happening here?
Sebastian
