I have 7of said motion sensor connected via a “SONOFF Zigbee 3.0 USB Dongle Plus” to my Rpi4 running HA dockerized. When freshly set up, they run reliably and fast until after a couple of weeks they will, one after another appear as “Unavailable”. Does anyone have similar experiences, or an idea what might cause this error?
Log:
"home_assistant": {
"installation_type": "Home Assistant Container",
"version": "2022.6.7",
"dev": false,
"hassio": false,
"virtualenv": false,
"python_version": "3.9.12",
"docker": true,
"arch": "aarch64",
"timezone": "Europe/Berlin",
"os_name": "Linux",
"os_version": "5.15.32-v8+",
"run_as_root": true
"custom_components": {
"hacs": {
"version": "1.25.5",
"requirements": [
"aiogithubapi>=22.2.4"
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zha",
"requirements": [
"bellows==0.30.0",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.75",
"zigpy-deconz==0.16.0",
"zigpy==0.45.1",
"zigpy-xbee==0.14.0",
"zigpy-zigate==0.7.4",
"zigpy-znp==0.7.0"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "10C4",
"pid": "EA60",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"codeowners": [
"@dmulcahey",
"@adminiuga"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"after_dependencies": [
"usb",
"zeroconf"
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 3334,
"manufacturer": "Philips",
"model": "SML001",
"name": "Philips SML001",
"quirk_applied": true,
"quirk_class": "zhaquirks.philips.motion.PhilipsMotion",
"manufacturer_code": 4107,
"power_source": "Battery or Unknown",
"lqi": null,
"rssi": null,
"last_seen": "2022-09-28T16:10:26",
"available": true,
"device_type": "EndDevice",
"signature": {
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4107, maximum_buffer_size=89, maximum_incoming_transfer_size=63, server_mask=0, maximum_outgoing_transfer_size=63, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 49246,
"device_type": "0x0850",
"in_clusters": [
"0x0000"
"out_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0008",
"0x0300"
"2": {
"profile_id": 260,
"device_type": "0x0107",
"in_clusters": [
"0x0000",
"0x0001",
"0x0003",
"0x0400",
"0x0402",
"0x0406"
"out_clusters": [
"0x0019"
"entities": [
"entity_id": "binary_sensor.livingroom_occupancy",
"entity_id": "sensor.livingroom_motionsensor_power",
"entity_id": "sensor.livingroom_illuminance",
"neighbors": [],
"endpoint_names": [
"name": "ON_OFF_SENSOR"
"name": "OCCUPANCY_SENSOR"
"user_given_name": "Bewegungsmelder",
"device_reg_id": "6e7a49c7fb24c04dd3020cc53df1f8b5",
"area_id": "wohnzimmer"
