I have been running a z wave in the standard home assistant integration, and I have about 90 devices. I have been having an intermittent issue with my z wave network in that it will be working fine for several hours, or even days, until all of the sudden, the entire network will stop responding. When I look at the logs, it will list all devices as timing out.
If I stop and then restart then network, then it will start working again. I’m not sure exactly why it is happening, or if it is a symptom of a software issue, a z wave stick issue, or something in the middle. If anyone has seen this issue before and has any insight, I would certainly appreciate it.
My setup right now: Latest version of Home assistant, running on an unraid docker, using the standard z wave integration, my z wave stick is a Nortek HUSBZB-1. The z wave stick is on an extension cable away from the main server.
