Hi all
Running HA in Docker, Ubuntu 20.02.
Yesterday I was playing around with getting zigbee2mqtt to work. Long story, but I ended up backing out the changes (or so I thought) and returning to the configuration as it was 24hours ago.
However HA is no longer detecting any zigbee devices via my Conbee II.
The devices are all listed, but are unavailable.
Nothing has changed hardware side - Conbee stick is still in the same USB port it always has been, but it is as if the stick itself is not being picked up by HA now.
Hoping I don’t need to go through the whole process of adding them again, but any ideas where I might have broken something?
Initial thoughts are that sharing the same USB device with zigbee2mqtt has created access issues but I have removed all traces (as far as I know) of z2m and performed multiple restarts.
In the process of troubleshooting, I have also noticed that Ubuntu always reports the USB is being in the same port regardless of me physically plugging it in somewhere else (i.e. it is ALWAYS ttyACM0 in the print out below). This doesn’t seem like correct behaviour?
user@server:/opt$ ls -l /dev/serial/by-id/
total 0
lrwxrwxrwx 1 root root 13 Jun 14 00:11 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2447455-if00 -> ../../ttyACM0
My core.config_entries has the following:
"entry_id": "a32c78449bcdf2e6b54f6408fd96f456",
"version": 3,
"domain": "zha",
"title": "ConBee II - /dev/ttyACM0, s/n: DE2447455 - dresden elektronik ingenieurtechnik GmbH - 1CF1:0030",
"data": {
"radio_type": "deconz",
"device": {
"path": "/dev/ttyACM0"
"options": {
"custom_configuration": {
"zha_options": {
"consider_unavailable_mains": 7200,
"enable_identify_on_join": true,
"consider_unavailable_battery": 21600
"zha_alarm_options": {
"alarm_failed_tries": 3,
"alarm_arm_requires_code": false,
"alarm_master_code": "1234"
"pref_disable_new_entities": false,
"pref_disable_polling": false,
"source": "usb",
"unique_id": "1CF1:0030_DE2447455_dresden elektronik ingenieurtechnik GmbH_ConBee II",
"disabled_by": null
With docker-compose.yaml looking like this:
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:stable"
volumes:
- /opt/homeassistant/config:/config
- /etc/localtime:/etc/localtime:ro
devices:
- /dev/ttyACM0:/dev/ttyACM0 #zigbee USB
restart: unless-stopped
privileged: true
network_mode: host
