Allesin M130 roller blinds
Hi Hassio community,
I have an Allesin M130 roller blind here and I’d like to control it with a Broadlink RM4-Pro via RF.
Unfortunately I don’t find anything about those blinds online. I was hoping they are are rebranded “standard” devices. I already tried to learn the RF commands the remote is sending with no success so far. I also tried broadlinkmanager, but the RM4-Pro doesn’t seem to pick up anything.
Any Ideas? Would it be possible to swap the motor with a Zigbee or Tuya device?
Thanks for the help & best regards
Alex
Check the stickers on the remote and ghe receiver for info on frequency used.
A FCC number might be used for that also.
the remote indeed says 433mhz. I can’t find anything else on the PCB as well. the rm4-pro doesn’t “see” the messages though
I got the app to learn codes at 433.72mhz but have yet to get it to actually do anything, or translate that to HA.
Any luck getting this set up? I have the same remote similar blinds.
Anyone get this to work? I’m in the same spot. I’m hoping the silence means someone got it …
Thank you!
Running into the same issue here, anybody have any luck?
I could not find the FCC filing for this remote, but I found it for the hub and and the 15-channel version of the remote. Unfortunately I think the actual codes are redacted, but did confirm its working on 433.92Hz
Maybe I will try to buy a SDR to listen to what its sending.
From the link from @Happyman I found out that the manufacturer is SunfreeMotor.
On their website I found some interesting downloads. I had not yet a chance to check out, but maybe someone else is interested to take a look.
I am trying to get the control using RFlink.
