Allow for multiple labels/areas in label_entities/area_entities
Currently, if you want to list all entities in a given area or all entities having a given label, you do this:
{{ area_entities('kitchen') }}
{{ label_entities('kitchen') }}
If you want all entities in multiple given areas you can do this:
{{ ['kitchen', 'bedroom', 'bathroom']
   | map('area_entities')
   | sum(start=[]) }}
(Practical example shown here).
Similarly, to get all entities having multiple given labels, you would do this:
{{ ['outdoor', 'battery', 'temperature']
   | map('label_entities')
   | sum(start=[]) }}
This Feature Request proposes simplifying the process by enhancing area_entities and label_entities so they support multiple entities as arguments.
{{ area_entities('kitchen', 'bedroom', 'bathroom') }}
{{ label_entities('outdoor', 'battery', 'temperature') }}
In effect, this FR asks to have them behave like expand which, when used as a function, can accept a comma-separated string or a list:
{{ ['group.doors_exterior', 'group.doors_interior'] | expand | list }}
{{ expand(['group.doors_exterior', 'group.doors_interior']) | list }}
{{ expand('group.doors_exterior', 'group.doors_interior') | list }}
You can also use a + operator:
  + area_entities('bedroom')
  + area_entities('bathroom') }}
Or several other inelegant ways which is why this FR was created
especially useful for iterating over combined sets of label_entities, an aspect not yet mentioned.
eg
{%- for s in ['binnenlamp','buitenlamp']
   | sum(start=[])
    |select('is_state','on') %}
{%- if states[s].last_changed.day == now().day %}
{%- set stamp ='%H:%M' %}
{%- else %} {% set stamp = '%d/%m - %H:%M' %}
{%- endif %}
{%- if loop.first %} {% else %}, {% endif -%}
{{states[s].entity_id}} ({{as_local(states[s].last_changed).strftime(stamp)}})
{%- endfor %}
it does work like this, but a
{{ label_entities('binnenlamp','buitenlamp') }}
would be so much cleaner.
adding my support here since the linked/split topic seems to be focussing on introducing new functions, while this is an enhancement of the current.
Also because the suggested
label_entities('bedroom') + label_entities('kitchen')
is no solution for the use case I showed above, cant be done like that
thx for opening it
next challenge:
select certain areas (dynamically later on, but for now have enumerated them) in several floors, then select individual lights that are on…
{{['dorm','aanbouw','woongedeelte']|map('floor_areas')|sum(start=[])
|reject('search',['dorm_marte','logeerkamer','studenten']|join('|'))
|map('area_entities')|sum(start=[])
|select('match','light')
|select('is_state','on')|list}}
this works alright, except this also targets light groups. so, I would like to replace the
with a selector using the
label_entities('binnenlamp')
or
['binnenlamp']|map(label_entities)
for that matter
but I can’t get the correct syntax.
please have a look what I could do here?
thx
edit
this seems to work:
|select('in',label_entities('binnenlamp'))
though I am wondering why I can not map the label_entities directly, and first have to map the area_entities
It’s a bit opaque, but all groups have an entity_id attribute you can filter for.
yeah, please read down that post above, I already found the way to select the label_entities() using
or, even use the same technique to again select from several labels:
{{['dorm','aanbouw','woongedeelte','buiten']|map('floor_areas')|sum(start=[])
|reject('search',['dorm','logeerkamer','studenten']|join('|'))
|select('in',['binnenlamp','buitenlamp']|map('label_entities')|sum(start=[]))
so, select a few floors, and
find the areas in those floors,
reject a few areas, then
find the entities in those selected areas, and
find the correct label_entities in those areas, and
finally select those of the desired state :wink:
now thats a one-liner right there a noob can only dream off - even though it only fits in one line when you have an ultra-wide screen :rofl:
or you add a scroll bar:
{{['dorm','aanbouw','woongedeelte','buiten']|map('floor_areas')|sum(start=[])|reject('search',['dorm','logeerkamer','studenten']|join('|'))|map('area_entities')|sum(start=[])|select('in',['binnenlamp','buitenlamp']|map('label_entities')|sum(start=[]))|select('is_state','on')|list}}
well, it’s long-liner :grin:
