Allow Image Attachments in Hangouts Notification
The current Hangouts Notification (https://www.home-assistant.io/components/notify.hangouts/) only supports text messages, and does not allow image attachments.
Alternatively, SMTP Notification (https://www.home-assistant.io/components/notify.smtp/) to send MMS via MMS Gateway allows this functionality.
According to the documentation
it should be possible to attach data (i.e. image file or url) but I can not get it to work with 0.80.1
Was anybody successfull?
I have tried using call service but can only send text messages, no images. Might be me though
So I have tried again, with correctly formatted json, and I am able to send attachments (fotos).
But as stated here at the moment this is only possible, when you call the service directly in the dev-tool.
The json would look like this (insert your conversationID!)
  "message": [
 {"text": "messagen text here"}
  "target": [
{"id": "conversationID"}
 "data":
   {"image_file": "/config/www/cam_captures/snapshot1.jpg"}
According to this this is supposed to be fixed a week ago but I can not get this to work in 0.81.0.
Here is my service-call:
- service: notify.hangouts
  data_template:
    message: 'Hallo'
      image_file: '/config/www/cam_captures/snapshot1.jpg'
Nothing is sent, not even the text alone. If I remove the last two lines, I receive the message in hangouts. And yes, the image exists and can be send via the dev-tools successfully.
Any ideas anybody? Maybe the fix didn’t make it in the latest version jet?
I struggled with this for a couple of hours yesterday but finally figured it out. If you use the hangouts.send_message service you can get it to work. I only have the JSON as I use node red but you can probably do something similar in YAML.
    "message": [
            "text": "Doorbell"
    "target": [
            "id": "insert_target_id_here"
    "data": {
        "image_file": "/config/webcam/snapshot.jpg"
Also, I had to whitelist the directory where my snapshots were stored. Place this code under homeassistant: in your config.
  whitelist_external_dirs:
    - /config/webcam
Everything seems to work since Version 0.82.1.
Also notify and attachments.
Works for me … this is great. :grinning:
It’d be be even better if we could do multiple image attachments rather than just the one
how do you guys use the image in an automation? for me it works only if i do it in an service call
this is my automation:
below doesnt work if i add image
  - service: hangouts.send_message
        - id: !secret hangouts_id
      message:
        - text: 'Alarm Aan'
        - image_file: "/config/www/images/snapshot_buiten.jpg"
this one works without image
      message:
        - text: 'Alarm Aan'
from service call manually it works with no issue
[{"text": "Alarm Aan!"}],"target": [{"id": "xxxx}],"data": {"image_file": "/config/www/images/snapshot_buiten.jpg"}}
This works fine for me now. In dev tools I run notify.hangouts with the following YAML:
message: Bevegelse i båten!
  image_file: /config/www/sofia.jpg
Attaches the image just fine. :slight_smile:
Yeah got it working too :wink:
