Allow modbus address/port/register to be specified in Hex
Many low level devices are documented using Hex notation.
To reduce effort & mistakes from integration developers converting these to decimal,
allow the modbus integration to parse address: port: and others*
to also use numbers like 0x1B34 or 3A6h
(*) Maybe slave:/status_register:/target_temp_register:
P.S. Other modules, like Bluetooth or Network, might also benefit from this sort of flexibility
This is already possible. Yaml accepts hex and converts everything to integers.
This:
field: 15
is the same as
field: 0x0F
Thanks. I thought I tested it and found that feature lacking.
(and went searching for Hex or Hex Format, and found no doco or examples)
Might propose some small doco updates
It’s a yaml thing, it’s not an HA thing
