I’m actually very happy with my Home Assistant and have very few wishes, as you can control and configure a lot yourself.
However, one thing bothers me a lot because it now seems very arbitrary.
I followed the recommendations and now use long term statistics. I have also removed all the “tweaks” from the recorder settings so that the recorder now works with the default settings.
Instead, I now use the long term statistics.
However, these only seem to work with sensor entities at the moment.
But there are a lot of other entity types that would benefit from long term statistics. Some of these can even include the same state_classes and units_of_measurements and behave in the same way as sensors in the history - except that they cannot be included in the long term statistics.
I therefore argue in favor of including additional entity domains in the long term statistics.
Primarily, from my point of view, this would include the data from the following entity domains, because they act pretty similar to sensors:
climate (the temperatures)
water_heater (the temperatures)
number (the value, can have device_class and unit of measurement just like sensors)
input_number (the value, can have device_class and unit of measurement just like sensors)
If you’re asking how many people want to know what their water heater temperature was at 6am a year and a half ago, I’d say very few. Like, single digits few.
Remember you can still retain the data for these specific entities using the recorder settings should you wish to. Others, however, might not be amused at seeing their db size increase over time, especially if they don’t have too much disk space to begin with.
The measurements you suggest tend to not be very accurate, as most devices measure these in, or close, to the device that is influencing them. So using separate thermometer/hygrometer entities to gather historical data is way better.
You seem to want to record pretty much everything. I believe many people do not take the time to configure recorder, so they will have way more data stored than needed. If you want to store this much data, Influxdb and Grafana seem to be the way to go for you.
First, thank you for your oppinion! I found wrong installations with statistics over time (almost every time water heaters, no joke! ) and I want so see optimizations for energy usage over time. Long time statistics doesn’t increase the db size, that is why they are enabled for all sensors with state_class.
My climate devices have an external sensor so the measurement is not less accurate than those from other sensors.
I use the standard settings for the recorder, so I lose those statistics after some days. I don’t want to have all the data, long term statistics don’t record pretty much everything. So I don’t want to record pretty much everything. If I want to do that, I could use the recorder and set a long storage time. I just need the hourly value and mid, max, min… Long term statistics are every efficient in what they store and how they are stored. That is why they are stored forever.
So I still think it would be a good addition, especially for climate entities.
I’m with you. Twice now I’ve caught early failure of a air conditioning unit by being able to compare energy usage and humidity to temperature setpoint, run status and room temperature, and having this data to definitively show premature compressor degradation has gotten the company to cover the cost of a new compressor before it became a problem (it’s been as high as 118°F here this week, so having an A/C unit down would be…impactful).
So apparently it is wanted and by design that I have to create sensors from my climate’s temperature attributes to make them available as long-term information while my stand-alone thermometers get the long-term storage by default?
I also have to add, that most of my climate-sensors are using thermometers detached from the radiator. Nevertheless I would never do such a design decision based on the assumption that most measurements might be inaccurate…it’s both temperatures, so it’d just be great to have them both equally available as long-term data!
You’re right - the water heater temperature at 6 AM a year ago might not be relevant for most people. But for debugging a heating system, PV system, or similar setups, it is invaluable. And in terms of storage, it’s hardly a concern since it wouldn’t be logging data every 15 seconds.
Beyond that, long-term temperature trends (and the used target temperature settings (!)) are crucial for assessing additional heating needs or for writing better automated heating controls (matching heating water target temperature to outside temperature etc).
That’s exactly what long-term statistics in Home Assistant should handle.
As it stands, many of us - including myself - have had to rely on many hacky workarounds, which have proven extremely useful but are cumbersome. Especially when Home Assistant isn’t just a side project but a full-fledged home automation system, managing everything from heating and PV to water, ventilation, lighting, and even the sewage treatment plant in my case.
Not the most useful comment, but i’m part of the few digits that log everything.
On my side, i have set the recorder to infinity of days. My only problem now is that i can’t update to ha2024.xx because there a query update that fails after a few hours. i guess the database is too large (70GB after ~7years).
It would be nice indeed to be able to select by entity what should be saved for long term statistics.
my instance is sending data to influxDb, but i have never actually used it, also i noticed the attributes are not set there.
I plan to manually create retroactive statistics from the state tables into influx/long_term_stats so i can clean it up . sql queries should not be a problem but i have no experience at all with influx.
Also, i really like the graphics/card in home assistant and how you can simply click and entity and have it’s history, that why i kept all the data there and never used the data in influxdb or the long term statistics.
I came here absolutely surprised that some of my entities were not storing long term statistics.
I do not think the type of entity or device matters at all, nor should it be a judgement call. If something is recording data in my home assistant, I want that data to be stored forever. Period.
I’m especially surprised my climate entities don’t have long term statistics. I’m almost mourning the loss, because it was data I thought I had and would be able to compare, and it’s just… gone. Incredibly disappointing.
How can we ensure we fix this so all data is stored long term in the future?
