Allow optional !input Trigger's in Automation Blueprints
As far as I know @ the moment you can only use limited templates for “triggers” in blueprints; so:
  • optional (Not Required) multiple sensor’s for A blueprint, is difficult ATM I.e. none, one or multiple input sensor’s.
E.g.
  input:
      name: Motion Sensor's ( Optional )
      description: ( Optional ) Motion Sensor/s
      default:
      selector:
        entity:
          domain: binary_sensor
          device_class: motion
          multiple: true
Recommendation:
  • When A blueprint renders ( saved/run/registered ), it just removes (or disables) the “trigger’s”, where the entity_id: !input “sensor” [ ‘eq’ none ]
E.g.
# Disabled when "!input sensor" is empty
  - platform: state
    entity_id: !input sensor
So there may be A work around, & that is to use a “none existent” entity_id for the default: but it just seems crude to me? & Causes the Blueprint not to except any end-user input (via GUI) at all @ the time of writing this.
E.g.
  input:
      default: binary_sensor.does_not_exist
      selector:
        entity:
          multiple: true
But ultimately having more templating options in blueprint trigger’s (&or perhaps “sensors:”) would be best. So if one wanted (as I do now) to write a blueprint that can use “expand” & filter entities (E.g. using “states.binary_sensor” ) in A trigger for A blueprint can’t currently.
