Was wondering if its possible to add stacked graphs for multiple solar sources in the new Energy Module. Currently I have 3 sources (5k inverter+1k inverter+1k inverter). I know I could use a template and manually add each one, but I would prefer to have them separated to see how they are behaving individually. The drawback of not having them stacked if I put the solar forecast, if I put 7kwh in the forecast I will always fall short because the small 1k inverters bars will start from 0 on the Y axis
Heres currently how my graph looks (the third inverter started showing after like 3pm since its when i added its source)
