I want to make the target temperature variable via the lovelace. The only sensible approach I could come up with was to not have the ‘below’ be a static number but parse the input_number as the condition checking my thermometer.
when I try to:
condition:
- condition: and
conditions:
- type: is_temperature
condition: device
device_id: [theID]
entity_id: [theOtherID]
domain: sensor
below: {{ states('input_number.temperatur') | int > 16 }}
I get the following error: “expected float for dictionary value @ data[‘below’]”
Is this possible at all and if not is there a better way to solve that problem?
here is the full automation:
alias: heizung_rick_an
description: "turn on if..."
- platform: time_pattern
minutes: /5
condition:
- condition: and
conditions:
- type: is_not_open
condition: device
device_id: 97a6c35d2bbe0b904c5608da21441e87
entity_id: binary_sensor.0x00124b00239df823_contact
domain: binary_sensor
condition: device
device_id: fdb0204af62a71adb201618ba4f16e63
entity_id: sensor.0x00124b002228f249_temperature
domain: sensor
below: 19
- condition: time
after: "10:00:00"
before: "21:00:00"
- type: turn_on
device_id: 0f919d72468301b1b2d3d38dbf23b70c
entity_id: switch.tasmota_2
domain: switch
mode: single
