I think the subject pretty much sums it up.
What else can I say?
You can use already use templates in the Services tool⌠so youâll need to say more.
Youâre in the yaml editor. The UI version doesnât support templates. I.e. Click âGO TO UI MODEâ, then templates will not work.
Maybe my terminology is wrong?
No, your terminology is correct, you donât understand the message.
When in yaml mode, templates work. When in UI mode, templates do not work. The error message is not letting you go to UI mode, and itâs stating why it canât go to UI mode. The reason is that UI mode doesnât support templates.
Bloody hell!
for years Iâve wanted this and itâs been possible forever (possibly).
In that case the wording is very misleading. Some context around the words âThe UIâ would be helpful.
But thanks for pointing this out. Iâm happy!
