Hi all,
I would like to propose changing the REstful Switch behavior when facing an HTTP bad request during its loading process.
Proposed change:
Current behavior:
Precondition: State providing API used in the RESTfull Switch is in an error state (404, 409, etc) and Home Assistant is rebooted
- An error is included in the log
- The switch entity is not created
Proposed behavior:
- The switch entity is created
Possible code changes:
File: https://github.com/home-assistant/core/blob/43b5dcff7631124e4509b6c951f3875ef7be905c/homeassistant/components/rest/switch.py
Current Code - Line 105:
req = await switch.get_device_state(hass)
if req.status >= HTTP_BAD_REQUEST:
_LOGGER.error("Got non-ok response from resource: %s", req.status)
else:
async_add_entities([switch])
Proposed Code:
Reason for prosing this
Right now I am trying to create a RESTful switch to control a plugging called PSU Control. I manage to get the switch up and running (configuration.yaml extract bellow) however I need to have the printer connected to octoprint when I restart Home Assistant because the Octoprint state API return 409 (details bellow)
switch:
# Ender 3 Control
# Ender 3 - PSU Control - Power Control
- platform: rest
resource: http://ender3.local/api/plugin/psucontrol
state_resource: http://ender3.local/api/printer
name: "Ender 3 - Power"
body_on: '{"command": "turnPSUOn"}'
body_off: '{"command": "turnPSUOff"}'
is_on_template: "{{ value_json.state.flags.operational }}"
headers:
Content-Type: application/json
X-Api-Key: 234844E83675497EBB4593AD4D8086C0
verify_ssl: false
**API response when the printer is not connected **
Response code 404 or 409
"error":"Printer is not operational"
**API response when the printer is connected **
"sd":{
"ready":false
"state":{
"error":"",
"flags":{
"cancelling":false,
"closedOrError":false,
"error":false,
"finishing":false,
"operational":true,
"paused":false,
"pausing":false,
"printing":false,
"ready":true,
"resuming":false,
"sdReady":false
"text":"Operational"
"temperature":{
Another use case that support this change is:
- A user has REST devices connected to his network using WIFI;
- The user creates RESTfull switches using the Wifi connected REST API
- User wifi network is down
- User restart Home Assistant while the wifi is down
In this case all RESTfull switches would disappear, and wouldn’t be recreated until the user restart his Home Assistant server after restoring Wifi. If the RESTfull swiches were created even with the wifi connected REST devices down, when the wifi was restored those switches would restart working.
What do you all think about this? Is there a deeper reason for not creating the RESTfull Switches? when getting an error from the API?
Let me know if you think it is a good idea, that I can take a stab in making this code change, it may take a while as I have no idea how to set up a Home Assistant development environment (I am reading the documentation right now)
