It’s no secret that the MyQ integration has been going Tango Uniform quite a bit recently. The problem seems to be the user-agent of the integration is changing. This can be easily “patched” by anyone who possesses some Linux skills, or they can wait for a new version to be published.
However, neither of these are ideal situations. Having to publish a new version of the software is a bit over the top, and for those that are relying on MyQ waiting is a frustrating experience. Sure, they can dust off some terminal and vi knowledge and follow one of the many step-by-step-keystroke-by-keystroke guides people are writing. For example, this one shows you how to update the user-agent in your docker container. It works great. But how about letting the end user specify the user-agent, as described by @ssilence (I’m assuming ssilence and ssilence5 are the same peeps). His solution is to allow you to set the user-agent in the configuration
# https://www.home-assistant.io/integrations/myq/
platform: myq
username: !secret myq_username
password: !secret myq_password
type: chamberlain
user_agent: 'myQ/14041 CFNetwork/1107.1 Darwin/19.0.0'
I know for some it’s anathema to rely on the internet because they are wedded to a closed system, but since MyQ has to use the internet anyways, why can’t this user-agent point to a simple URI such as text file in the repo?
If someone shows me how to find what the new user agent should be, I’ll write and publish a service that will create a URI for everyone to use. Basically an automation that discovers MyQ has stopped working, finds the correct user-agent and publishes it somewhere.
I’m not hardcore on a particular implementation, but we really should find an easier way for people to update this setting that doesn’t require waiting for a new build or hitting up the command line.
Thoughts?
Pinging @bdraco, @ChadGnad, @GaryOkie (please add others who you’ve seen express interest in this issue)
