Currently Home Assistant allows you to move the data disk out to another disk of larger capacity.
It would be able to allow moving to a smaller disk if required.
I was planning to do a number of things with HA, so I installed a large size SSD and moved the data disk to it. Then I decided I would go in a different direction, and the only way to move to a smaller disk would be to rebuild the system user a smaller disk.
Agreed. I have just changed my PiHA SD card to a new one (64Gb which was cheapest) but also bought a small usb to use as the data storage vs the SD (32Gb) but it won’t let me use the data storage even though the actual current installation is only 10% ( so what , 6.4Gb? ) and the data portion should easily fit on the 32Gb.
Ok this is ridiculous. I bought a 64Gb transcend usb stick to try and get this move working. Now when I tried it, the usb is STILL smaller, supposedly by a couple megabytes, can we please get some option to work around this as I’ve now bought two sticks and can"t use them for this.
Can I move the data to an equal size disk? Also, what happens if I do a backup up my system, where the data disk is an external USB disk of 1 TB, and then do a fresh installation of HA and restore the backup? Can I restore the backup to my internal disk or do I still need to restore it to the external disk?
I’m not sure about the equal size disk. I would try and if it doesn’t work, back up and restore.
As far as restoring to the internal disk, I believe you can, as long as all your data fits. Otherwise, you would have to install, move the data disk, and then restore from your backup.
I did the same. Use backup, create new ha on a smaller SD, restore the backup, add the 80GB SSD and move the data to the SSD. The led on the SSD shows clearly how often it is writing.
Worked fine.
Hi could you please help to explain more on how to create new ha on a smaller SD? I inserted a SSD and moved the data to it, but now i want to swap to a smaller SSD. Can I backup then download the backup file, then create new ha on the HA yellow disk itself?
