It would be nice to be able to have a dynamic offset when using the sun platform as a trigger. With the advent of blueprints, this becomes essential in some scenarios.
Right now this:
- platform: sun
event: sunrise
offset: "{{ some_logic_here }}"
Use the sun elevation instead. That gives you a consistent light level through the year - -3 degrees is the same light level on the shortest day as the longest day.
That’s a good suggestion consistency-wise. But it’s hard to relay the significance of -x or x to blueprint users. I know this may sound condensing, but I myself don’t know how my automation will work if I use -3.
Regardless of the good suggestion, I think offset should accept variables.
