I’m new to Home Assistant. I have installed it on a Raspberry Pi 4 and I want to make it accessible from outside my network.
I have followed tutorials on how to do this with duckdns and one of the requirement is to edit the configuration.yaml file and add the following lines:
If I remove these lines and reboot my Raspberry, Home Assistant becomes available again.
What is wrong with my configuration file ? In the logs I don’t see anything relevant as to why it is not starting. And on top of that, the configuration checker tool says my configuration file is valid
ok, I have made progress. It seems I can access Home Assistant after all. But only through https :
and the certificate is not valid.
@deluxestyle you replied at the same time as me. Yes I’m forwarding port 8123 to my raspberry, although I’m having a hard time figuring out if this is really working. No, the certificate is not valid, alhtough I don’t see why as it is set to expired on April 6 2022. But obvioulsy it was emitted for domain mydomain-duckdns.org and not homeassistant.local
As soon you have https in your config it can only be reached by https
The ssl certificate is also only for your duckdns domain
Are you using the duckdnks addon?
Internal you have to accept the certificate in your browser
Yes, I have installed the duckdns addon. However I cannot get access from outside my network. If I browse to https://my-domain.duckdns.org:8123 I get a ERR_TUNNEL_CONNECTION_FAILED error in my browser. Could this be that port forwarding is not working properly ?
When I ping my domain name provided by duckdns, it fails (host unreachable). I have a optical fiber modem installed by my ISP to which my router is connected. I wonder if something should be done at that level but I don’t have any way to interact with it.
Ok, so I guess I cannot access it with the domain name from local network. However when I try to access it from outside using a 4G connection, I get ERR_ADDRESS_UNREACHABLE.
If I run port scan from outside, I have the following results :
Nmap scan report for my-domain.duckdns.org (my real ip is found)
Host is up.
PORT STATE SERVICE
21/tcp filtered ftp
22/tcp filtered ssh
23/tcp filtered telnet
80/tcp filtered http
110/tcp filtered pop3
143/tcp filtered imap
443/tcp filtered https
3389/tcp filtered ms-wbt-server
443 is filtered, which may be the problem ? However I did open it with port forwarding in my router configuration as shown above
I believe my problem is that I don’t have a public IP address. My router is behind my ISP modem, and the IP Address I see in my router configuration is NOT the one I see if I search on ‘what’s my IP’. Therefore my router remains ‘hidden’ behind that private IP address.
I will call my ISP tomorrow, I know they offer dynamic public IP address for a small monthly fee.
