Allowlist_external_dirs Integration not found Error
I try to save video from my BLINK camera to hass.
My configuration:
____________________________-
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
allowlist_external_dirs:
  - '/homeassistant/videos/'
script: !include scripts.yaml
scene: !include scenes.yaml
________________________________-
when I start hass I get following error:
Logger: homeassistant.setup
Source: setup.py:221
First occurred: 16:13:40 (1 occurrences)
Last logged: 16:13:40
Setup failed for 'allowlist_external_dirs': Integration not found.
System is Rasperry Pi HAOS:
I am stuck, please help!
changed configuration.yaml as follows:
default_config:
homeassistant:
    - '/config/videos'
    - '/config/snapshots'
then restarted HA in safe mode and the again normal mode
Now it is working OK.
For me safe mode and back to normal dis not help.
I confirm it solved also for me.
Thanks,
homeassistant:
- ‘/tmp’
- ‘/snapshots’
- ‘/video’
I couldn’t restart in safe mode with this error:
Failed to restart Home Assistant
The system cannot restart because the configuration is not valid: Invalid config for ‘homeassistant’ at configuration.yaml, line 10: Not a directory ‘allowlist_external_dirs->2’, got ‘/video’ Invalid config for ‘homeassistant’ at configuration.yaml, line 9: Not a directory ‘allowlist_external_dirs->1’, got ‘/snapshots’
Most probably you have an indentation error in the above, but we cannot tell you what it is since you didn’t format your code correctly.
