Allowlist_external_dirs: Integration not found
In Homeassistant started with docker I have a configuration.yaml:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
alarm_control_panel:
  - platform: manual
# Bitcoin
  - platform: bitcoin
    currency: CHF
    display_options:
      - exchangerate
      - trade_volume_btc
      - number_of_transactions
#      - miners_revenue_usd
#      - btc_mined
#      - hash_rate
# for access to store snapshots taken by Blink
allowlist_external_dirs:
  - /share/appdata/HomeAssist/Snapshots
script: !include scripts.yaml
scene: !include scenes.yaml
when starting HA the following error shows:
 ERROR (MainThread) [homeassistant.setup] Setup failed for 'allow_external_dirs': Integration not found.
Get almost crazy, what the heck is wrong?
with YAML the indentation is important, so you have to put the allowlist_external_dirs underneath the homeassistant configuration like here:
https://www.home-assistant.io/docs/configuration/basic/
  • raspberrypi 5,
  • Core 2024.3.3
  • Supervisor 2024.03.0
  • Operating System 12.1
  • Frontend 20240307.0
I was having the same issues. I have a script:
alias: take snapshot
sequence:
  • service: camera.snapshot
    metadata: {}
    filename: /config/reolink/photo/filename.jpg
    entity_id: camera.doorbell_snapshots_clear
    mode: single
Here are the steps I took to correct it.
see: Setup basic information - Home Assistant
but pay close attention to the NOTE in blue.
  1. add to my config.yaml
default_config: # already in file
homeassistant:
    - "/config/reolink/photo"
    - "/config/reolink/video"
    - "/tmp"
  1. In a terminal or ssh:
chmod 766 /config/reolink
chmod 766 /config/reolink/photo
chmod 766 /config/reolink/video
3: rebooted ( I rebooted the whole system)
after this, my script worked as planned.
After more investigation: I am changing the 777 to 766.
but I am still wondering if a change of permission is needed.
Read up on 777, highly unadvisable
I know the 777 gives full access to everyone, but everyone is just me. The only thing in the directory is a picture of the people standing at my front door. After working with it, I don’t think that step is needed. Now it is working I will remove the access and see what happens.
I am also trying to get this allowlist_external_dirs to work so I can use the File service, but I keep getting an error on loading the config.
I’ve tried:
default_config:
frontend:
sensor: !include sensors.yaml
  - "/share/data"
But when I run the config checker I get the warning:
Configuration warnings
Integration error: allowlist_external_dirs - Integration ‘allowlist_external_dirs’ not found.
This is practically a direct copy from the HA instructions so I don’t understand what I’m doing wrong. Please can anyone explain what I’m doing wrong here?
it needs to be under your homeassistant: section and indented like this
homeassistant:
    - '/share/data'
work ok now?
I have the same issue. My config is like this:
default_config:
homeassistant:
whitelist_external_dirs: ‘/tmp’
allowlist_external_dirs: ‘/tmp’
Cheers
Please format your code
f6be36681e0da431418ec7781fb6c62712941803
Ok ite December 2024 and its been a while but hey this popped up so
I added this at the end
homeassistant:
- ‘/image’
I made the folder
The indentation matches armed BUT configuration check failed with
Configuration errors
Invalid config for ‘homeassistant’ at configuration.yaml, line 42: Not a directory ‘allowlist_external_dirs->0’, got ‘/image’
Thoughts and prayers??
got it!!! search around. I can across a discussion about this and how it related to containers. I running under HAOS so not h familiar with containers BUT found if I changed to this
homeassistant:
- ‘/config/image’
- ‘/config/roll’
HA configuration checker ws happy and everything worked…!!
this is cool, but, ah, where is this?
In configuration.yaml
homeassistant:
  customize: !include customize.yaml
  packages: !include_dir_named packages
    - "/config"
No, I am sorry, I meant the Code formatter in your gif, that seems helpful
